Beeldscherm kantelen
Re: Beeldscherm kantelen
Genereer dan meteen xorg.conf en post die ook, scheelt weer
Nou, ik hoop dat dit iemand wat duidelijkheid geeft...
Ik begin inmiddels de neiging te krijgen gewoon maar opnieuw te installeren om van dit gepuzzel af te zijn.
Nu heb ik niet best geslapen vanacht dus ik zal geen wilde beslissingen nemen ;)
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 1680 x 1050, maximum 1680 x 1050
default connected 1680x1050+0+0 0mm x 0mm
1680x1050 0.0*
1280x1024 0.0
1024x768 0.0
800x600 0.0
640x480 0.0
X.Org X Server 1.11.3
Release Date: 2011-12-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.42-76-generic i686 Ubuntu
Current Operating System: Linux sven-H81-D3 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=cb65a6be-dce7-4d25-8619-06527650815f ro quiet splash vt.handoff=7
Build Date: 12 February 2015 02:51:26PM
xorg-server 2:1.11.4-0ubuntu10.17 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.30.2
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Mon Aug 22 14:03:18 2016
List of video drivers:
intel
mga
ati
savage
sisusb
neomagic
trident
r128
ztv
openchrome
radeon
siliconmotion
sis
geode
cirrus
mach64
vmware
tdfx
s3
nouveau
qxl
fbdev
vesa
(++) Using config file: "/home/sven/xorg.conf.new"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Number of created screens does not match number of detected devices.
Configuration failed.
ddxSigGiveUp: Closing log
Server terminated with error (2). Closing log file.
Probeer dit eens (eventueel left in right veranderen als dat de bedoeling is ;) )
xrander werkt gewoon als ik je output zo zie. Alleen snapt hij niet hoe je scherm is aangesloten (vandaar 'default' en niet iets moois als LVDS1) maar dat zou niet uit moeten maken.
xrandr --output default -o left
Had ik denkk ik al geprobeerd, werkt helaas niet:
