Postprocessor Vectric Cut2d Eding CNC
Zee&Zee
Bericht door Zee&Zee »
Welke postproccesor kan ik het beste pakken uit die megalijst in Vectric Cut2d voor gebruik met Eding CNC ?
Ik heb nu de Gcodes Arc mm PP geprobeerd in Cut2d en de Vectric Vcarve PP uit de knowledgebase van dit forum gedownload, beide lijken het te doen...maar ik snap (nog) niks van Gcodes dus vraag me af wat het verschil is of beter is om te gebruiken ?
CNC you later
Re: Postprocessor Vectric Cut2d Eding CNC
gcode voor 3 assen is best leesbaar nmi
heb je dit gezien :
http://cnczone.nl/viewtopic.php?f=39&t=9834
Laatst gewijzigd door keesfrees op 09 sep 2014 12:59, 1 keer totaal gewijzigd.
Ik heb ooit eens voor mijn machien(met edingcnc) deze geschreven:
+ G Code - Vectric machine output configuration file   - with Arc support
POST_NAME = "Kees G-Code_Arc (*.nc)"
FILE_EXTENSION = "nc"
UNITS = "MM"
+    Line terminating characters
LINE_ENDING = "[13][10]"
+    Block numbering
LINE_NUMBER_START     = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+    Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
+    Block definitions for toolpath output
+  Commands output at the start of the file
begin HEADER
"G17"
"G0 [ZH]"
"G0 [XH] [YH] [S] M3"
+  Commands output for rapid moves
begin RAPID_MOVE
"G0[X][Y][Z]"
+  Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"G1[X][Y][Z][F]"
+  Commands output for feed rate moves
begin FEED_MOVE
"[X][Y][Z]"
+  Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"G02 [X] [Y] [I] [J] [F]"
+  Commands output for clockwise arc  move
begin CW_ARC_MOVE
"G02 [X] [Y] [I] [J]"
+  Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"G03 [X] [Y] [I] [J] [F]"
+  Commands output for counterclockwise arc  move
begin CCW_ARC_MOVE
"G03 [X] [Y] [I] [J]"
+  Commands output at the end of the file
begin FOOTER
"G0[ZH]"
"G0[XH][YH]"
"M30"
Kun je al die andere weg gooien of ergens anders parkeren.
Zee&Zee
-> Top Kees, ga ik proberen die zou wel in de knowledge base mogen ? En/of op de site van Bert ?
-> Kesfrees: Had ik niet gezien.. maar die Fanuc benadering wel geprobeerd Cut2d gaf een error in Eding en dan ontbreekt het me aan de kennis omdat ff eruit te halen/veranderen zonder dat ik bang ben het juist erger te maken.
CNC you later
Lekker overzichtelijke Postprocessor,
maar ik neem aan dat je niet heel langzaam freest, zou ik die feed ook op 1.0 zetten ipv1.1.
( als mijn interpretatie van decimalen achter de komma tenminste klopt )
Een F200.3 zou ik me tamelijk gaan storen als het weining toevoegd.
( net als al die schermen met 4 decimalen achter de komma die met mm werken en niet in inch :shock: )
hugo stoutjesdijk schreef: zou ik die feed ook op 1.0 zetten ipv1.1.
Je hebt gelijk... Die .1 is het aantal decimalen achter de komma (of punt)
Ik zie het bij EdingCNC ook niet terug.. Als ik F2000 invul gaat hij gewoon met 2 meter per minuut door het materiaal.
Overigens vertoont de postprocessor van ArtCam heel veel overeenkomsten. Daar heb ik 'm ook gemaakt en vrijwel een-op-een overgezet naar Vectric. (@ wordt A en verder heeft Vectric nog een paar keywords)
Voor de Artcam postprocessor heb ik nog een goede beschrijving in PDF voor wie er iets meer van wil weten.
Zee&Zee
Kwam voor vectric ook net zo'n PDF documentje tegen (ben me er nog wat verder in verdiepen nav de opmerkingen van Hugo, die ik nooit zelf had gevonden/bedacht)
http://forum.vectric.com/viewtopic.php?f=4&t=6213
CNC you later
kris blancke
Bericht door kris blancke »
USBCNC gebruik ik hier met Vcarve.
jlfbos
Bericht door jlfbos »
Ik gebruik met Vectric en Eding-CNC :
G-Code(mm)
is een *.tap file
Probleemloos
Jan
