CNC frees voor de massas.
Brunow
Bericht door Brunow »
http://www.sears.com/sr/javasr/product. ... &ihtoken=1
youtube links: http://youtube.com/results?search_query ... ve&search=
Craftsman CompuCarve Compact Woodworking Machine, Computer-Controlled
Compact, computer-controlled, 3-dimensional woodworking machine with an easy-to-use interface. It allows a novice to make a complete project without a shop full of tools.The unique configuration allows it to perform many other woodworking functions, including ripping, cross cutting, mitering, contouring, jointing and routing. The CompuCarve can work in most soft materials, including wood, plastics (polycarbonate or cast acrylic) and certain types of high density foam. Set includes CompuCarve machine, (1) 1/16 in. carbide carving bit, (1) 1/8 in. carbide cutting bit, CarveWright Memory Card, starter software package, (2) 1/4 in. bit adaptors, vacuum bag adaptor, bit removal tool, hex wrench, owner's manual and Quick Start Guide.
# Built-in computer walks you through project setup
# QuickRout technology makes changing bits quick and easy
# Memory card - no need to keep a computer in the shop
# CarveWright design software is powerful yet easy to use - even novices can create complex designs in minutes
# Expandable 3-D design library
# Patented rising-head and feed-through configuration handles work pieces up to 14-1/2 in. W, 5 in. H and almost any length
# Allows you to achieve professional results regardless of space, time, budget or skill
# Requires a PC running Windows 2000 or XP with 128 MB RAM (256 MB or greater recommended), 75 MB of hard drive space and an accelerated graphics card with OpenGL support
lijkt me wel een grappige toestel. Alsook de reacties op die site :)
Groeten
