Release notes V4.03 (25-10-2018)
http://www.edingcnc.com/index.php?pagin ... 3&taalid=2
24-10-2018 v4.03.30
+Wolfcut camera alignment check can be hidden (showWCCameraOption = 0 on cnc.ini)
+Zmin button voor plasma can be hidden (showPlasmaMinButton = 0)
+DXF engrave laser frequency and laser power order changed.
+64 automatic vacuum sections, software detects which one to switch on.
+ Support for 8 IO cards on CNC760 and iCNC600, this give 128 extra inputs/outputs.
+New kinematic functions for two X axes.
Kin x2a :moves A motor by X coordinates.
Kin x2xa :moves X + A motor with X coordinates.
Kin off :back to normal operation
+ New tangentialknife commands
tanknife a :Moves joint A in tangential knife mode when Cartesian C moves.
tanknife ac :Moves joint A and C in tangential knife mode when Cartesian C moves.
tanknife abc ::Moves joint A and B and C in tangential knife mode when Cartesian C moves.
+ Homing without tandem now shows step-loss again after the 2nd home move, with tandem the 3rd home move.
+ New wireless pendant support.
!!!! For all users, please select wireless pendant type in the set-up.
