@Serum
Thanks for the hint, we will activate that with our next tests
@kjelt
I think I dont get those: What/Where is this MDI where we should enter the commands ?...you will first use the camera, therefor go to the MDI and type M97...
...Now by pressing in the MDI G0 X0 Y0 your spindle should now be directly above....
If I understand correctly, this should solve our offset problem, but not the G43 error, since this error is caused by the macro. So we either have to fix the macro somehow, or we could do it manual as described in your post, is this correct ? I can check for the userdefined macro, Im not sure if I posted the correct one, there where more .CNC files i the folder.
The error L634: G43 .... does this mean Line 634 ? And should I see G43 command there in file ? This would help me to locate the correct one :)
One thing I dont really understand is the zeroing of the workpiece : I understand we have to do this for normal milling. But now I use the camera, which uses registrations marks, why still zeroing ? We have the marks and we have the offset between Cam & Spindle (M97 in the cnc.ini) I would assume that should be enough information
Thank again
Heiko
