Aanpassen G-code toolsetter en postprocessor
coremans
Bericht door coremans » 16 mei 2019 20:37
Hallo iedereen ,
Graag zou ik de G-code van de toolsetter en Postprocessor iets willen aanpassen , zou iemand kunne zeggen of ik dat juist doet?
Voor de toolsetter , wil ik na het meten dat de spindle geheel omhoog gaat (Machine :Z=0).
Dit is de toolsetter code die in USB-cnc zit:
;Zero tool tip example
Sub user_1
     msg "user_1, Zero Z (G92) using toolsetter"
    f30                (Start probe move, slow)
    g38.2 G91 z-100     (Move back to touch point)
    g0 G90 z#5063      (Set position, the measuring device is 43mm in height, adapt for your measuring device)
    G92 z42.55
    g91           (incremental distance mode)
    g0g91 z5.0    (move 5 mm above measuring device)
    g90           (absolute distance mode)
    M30
Endsub
Als ik dit erin zet: G53 z0 Is dat voldoende? Dan wordt het dit ( 3-na laatste regel):
Sub user_1
    G92 z42.55          (als de Z te hoog uitkomt bij Z0 dan de toolsetter hoogte "g92"verhogen")
    G53 z0
    M30
Endsub
Voor de postprocessor heb ik deze code:
+ Vectric Maschinenausgabe-Konfigurationsdatei
+ DJ-Bino's PP für VCarvePro
+ DJ-Bino's PP für USBCNC(V3)
+ History
+ wer      DD/MM/JJJJ   was
+ DJ-Bino  24/06/2008   PP geschrieben
+ Tony     24/06/2008   Kreisbögen u. Kreise hinzugefügt
+ DJ-Bino  24/06/2008   Kpl. Überarbeitet für USBCNC(V3)
POST_NAME = "USBCNC(V3)_AWW_Kreise_(mm)_(*.NC)"
FILE_EXTENSION = "NC"
UNITS = "MM"
+    Satzende Zeichen
LINE_ENDING = "[13][10]"
+    Satz Nummerierung
LINE_NUMBER_START     = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+    Variablen formatieren ( zuweisen )
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
+  Definition der NC-Sätze für die Werkzeug-Wege
+  Definition des NC-Programm-Kopf's ( Anfang )
begin HEADER
"[N] G00 G40 G90 G21"
"[N]  ( Prog-Name: [TP_FILENAME][TP_EXT] )"
"[N]  (************* VCarvePro *************)"
"[N]  (  Rohteil-Abmessungen in  X  Y  Z    )"
"[N]  (  X Breite = [XLENGTH] )"
"[N]  (  Y Länge  = [YLENGTH] )"
"[N]  (  Z Höhe   = [ZLENGTH] )"
"[N]  (++++++++++++++++++++++++++++++++++++++)"
"[N]  (   Nullpunkt-Lage im Rohteil X Y Z    )"
"[N] (  X Min = [XMIN]    X Max = [XMAX] )"
"[N] (  Y MIN = [YMIN]    Y Max = [YMAX] )"
"[N] (  Z Min = [ZMIN]    Z Max = [ZMAX] )"
"[N] (**************************************)"
"[N] (  Ausgangs Position X Y Z             )"
"[N] (  X = [XH] Y = [YH] Z = [ZH] )"
"[N] (  Sicherheits-Höhe in Z               )"
"[N] (  Z = [SAFEZ] )"
"[N] ( PP Ausgabe für USBCNC(V3)            )"
"[N] (    *** -- Werkzeugwechsel: -- ***    )"
"[N] ( Bearbeitung:      [TOOLPATH_NAME] )"
"[N] ( Werkzeugname:     [TOOLNAME] )"
"[N] ( Werkzeugnummer:   T[T] )"
"[N] ( Vorschub:         [FC] mm/min )"
"[N] ( Eintauch-Geschw.: [FP] mm/min )"
"[N] ( Spindeldrehzahl:  [S] U/min )"
"[N] T[T] M06 [S] M3 "
"[N] G00 [ZH]"
"[N] G00 [XH] [YH] "
+  Defenition des Werkzeugwechsels
begin TOOLCHANGE
"[N] ( Vorheriges Werkzeug: T[TP] )"
+  Definition Verfahrwege im Eilgang
begin RAPID_MOVE
"[N] G00 [X] [Y] [Z]"
+  1. Definition Verfahrwege im Vorschub
begin FIRST_FEED_MOVE
"[N] G01 [X] [Y] [Z] [F]"
+  2. Definition Verfahrwege im Vorschub
begin FEED_MOVE
"[N] G01 [X] [Y] [Z]"
+  1. Definition Verfahrwege Kreis im Uhrzeigersinn
begin FIRST_CW_ARC_MOVE
"[N] G02 [X] [Y] [I] [J] [F]"
+  2. Definition Verfahrwege Kreis im Uhrzeigersinn
begin CW_ARC_MOVE
"[N] G02 [X] [Y] [I] [J]"
+  1. Definition Verfahrwege Kreis im Gegen-Uhrzeigersinn
begin FIRST_CCW_ARC_MOVE
"[N] G03 [X] [Y] [I] [J] [F]"
+  2. Definition Verfahrwege Kreis im Gegen-Uhrzeigersinn
begin CCW_ARC_MOVE
"[N] G03 [X] [Y] [I] [J]"
+  Definition des NC-Programm-Kopf's ( Ende )
begin FOOTER
"[N] ( Grundstellung anfahren )"
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
"[N] M30 ( Programm Ende )"
Graag zou ik willen dat aan het einde van het frezen de spindle naar x0,y0,z0 ( machine) gaat.
Is het juist als ik de postprocessor aanpast , laatste regels van de PP code :
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
Wordt dan:
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
"[N] G53 z0"
"[N] G53 x0 y0"
Heel erg bedankt,
Cor
Linki
Re: Aanpassen G-code toolsetter en postprocessor
Bericht door Linki » 16 mei 2019 21:03
Deze regel veranderen in:
g0g90z0
De regel er boven: g91 (incremental distance mode)
Mag dan weg
Meer is het volgens mij niet.
coremans
Bericht door coremans » 17 mei 2019 21:05
@ linki, Cool , dat ga ik morgen eens proberen.
En voor de postprocessor , dat deze naar z0 , en dan naar x en y 0 gaat?
g0g90z0
g0g90x0 y0
Dit zijn de laatste regels in de postprocessor:
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
Zou het moeten werken als ik dit ertussen zet?
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
"[N] g0g90z0"
"[N] g0g90x0 y0"
Bedankt,
Cor
Bericht door hugo stoutjesdijk » 18 mei 2019 10:39
Niet de G53 weglaten op het kritieke moment. (machine coördinaten)
G90, G0, G53 zijn allemaal modaal, dwz, die hoef je maar 1x te schrijven en dan blijft het totdat het overschreven wordt met een andere G-code uit dezelfde groep. Maar je mag het wel in elke regel zetten als je dat prettig vind.
Dit is dus hetzelfde:
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
"[N] G53 G0 Z0"
"[N] X0 Y0 M30 ( Programm Ende )"
coremans
Bericht door coremans » 23 mei 2019 20:39
Eindelijk tijd gehad om het aan te passen .
Het werkte niet in ene keer:
De toolsetter , ging met G90 ipv machine Z-0 , naar work Z=0 :-s .... gelukkig stond de toolsetter er niet onder.
Heb het dan veranderd in:
Sub user_1
    G53 g0 z0
    M30
Endsub
Voor de postprocessor , moest ik er 2x G53 inzetten. Met de code hieronder ging alleen de Z , naar machine coördinaten 0, de X en Y niet.
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
"[N] G53 G0 Z0"
Heb het dan verander in:
"[N] G00 G40 [ZH]"
"[N] S0 M05 M09"
"[N] G53 G0 Z0"
"[N] G53 G0 X0 Y0 M30 ( Programm Ende )"
En nu ging wel eerst de Z naar machine coördinaten 0 , en daarna de X en Y naar 0
Bedankt voor de hulp,
Cor
