Wie kan mij helpen?
Ik heb in het verleden op oude Ferarri machines gewerkt waar wij grote programma's moesten opsplitsen en door middel van een knoop programma deze kleine programma's als een soort playlist konden aflopen.
Nou zou ik ditzelfde graag op Heidenhain besturing doen.
Twee werkstukken opspannen en dan twee programma's (of meer) na elkaar laten lopen.
Zijn hier ook knoop programma's, of andere mogelijkheden voor?
Heidenhain programma's knopen
Re: Heidenhain programma's knopen
Bij Heidenhain kun je gewoon vanuit het ene programma het andere oproepen. Even de handleiding van de betreffende besturing opzoeken/downloaden......
Even zoeken :
PROGRAM CALL (Cycle 12)
Routines that you have programmed (such as special drilling cycles or
geometrical modules) can be written as main programs and then
called like fixed cycles.
Before programming, note the following:
The program you are calling must be stored on the hard
disk of your TNC.
If the program you are defining to be a cycle is located in
the same directory as the program you are calling it from,
you only need to enter the program name.
If the program you are defining to be a cycle is not located
in the same directory as the program you are calling it
from, you must enter the complete path (for example
TNC:\KLAR35\FK1\50.H.
If you want to define an ISO program to be a cycle, enter
the file type .I behind the program name.
As a rule, Q parameters are globally effective when called
with Cycle 12. So please note that changes to
Q parameters in the called program can also influence the
calling program.
Program name: Enter the name of the program you
want to call and, if necessary, the directory it is
located in.
Call the program with
CYCL CALL (separate block) or
M99 (blockwise) or
M89 (executed after every positioning block)
Example: Program call
A callable program 50 is to be called into a program via a cycle call
Even zoeken :
disk of your TNC.
calling program.
located in.
M99 (blockwise) or
BEGIN PGM 123456 MM
;BOREN STRIP RECHTS
;aanroep basis nulpunt klem16-4
CALL PGM KLEM16-4
BLK FORM 0.1 Z X-176 Y-50 Z-20
BLK FORM 0.2 X+325 Y-10 Z+0
; en zo verder
Het is natuurlijk logisch dat er in dat aangeroepen programma geen M30 (einde programma) staat, dat gaat ie echt niet verder.
dank u vriendelijk, hier ga ik een heel eind mee komen!
