Linuxcnc start niet op in nieuw OS
Bericht door Sven » 08 jan 2019 15:05
Na het instaleren van debian werkt mijn configuratie niet meer, ik krijg deze melding:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.6
LINUXCNC - 2.7.14
Machine configuration directory is '/home/sven/linuxcnc/configs/Alu-XYZA'
Machine configuration file is 'Alu-XYZA.ini'
INIFILE=/home/sven/linuxcnc/configs/Alu-XYZA/Alu-XYZA.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./Alu-XYZA.hal
hm2: loading Mesa HostMot2 driver version 0.15
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_5i25.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_5i25.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0:     IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 010 (P3-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0:     IO Pin 011 (P3-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0:     IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0:     IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0:     IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
hm2/hm2_5i25.0:     IO Pin 015 (P3-12): Encoder #0, pin B (Input)
hm2/hm2_5i25.0:     IO Pin 016 (P3-13): Encoder #0, pin A (Input)
hm2/hm2_5i25.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
Found file(LIB): /usr/share/linuxcnc/hallib/xhc-hb04.tcl
xhc-hb04.tcl: Using existing outpin signame: spindle-cmd-rps-abs
Starting TASK program: milltask
DELAY=
APP: xhc-hb04-accels found: </usr/bin/xhc-hb04-accels>
APP: monitor-xhc-hb04 found: </usr/bin/monitor-xhc-hb04>
Starting DISPLAY program: axis
[color=#FFBF40]ERROR Can't open the device /dev/spindelregeling (errno 22)
vfd: ERROR: couldn't open serial device[/color]
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=1675
Killing task milltask, PID=1713
task: 86 cycles, min=0.000006, max=0.021240, avg=0.008012, 0 latency excursions (> 10x expected cycle time of 0.010000s)
xhc-hb04: waiting for XHC-HB04 device
xhc-hb04: found XHC-HB04 device
xhc-hb04: connection lost, cleaning up
hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Vervolg hieronder.....
Met name de regel " ERROR Can't open the device /dev/spindelregeling (errno 22)
vfd: ERROR: couldn't open serial device" is denk ik een dingetje.
Ontbreken er dan drivers voor de seriële poort?
Beginnen met CNC?
Re: Linuxcnc start niet op in nieuw OS
Bericht door Sven » 08 jan 2019 15:06
Vervolg foutmelding:
Debug file information:
pickconfig: installed aux examples: /usr/share/linuxcnc/aux_examples/NativeCAM
./Alu-XYZA.hal:4: Warning: File contains DOS-style line endings.
Note: Using POSIX realtime
xhc-hb04.tcl: using std_start_pause_button
Can not find -sec APPLICATIONS -var DELAY -num 1
open: No such file or directory
custom_postgui.hal:6: waitpid failed hy_vfd vfd
custom_postgui.hal:6: hy_vfd exited without becoming ready
1675
  PID TTY      STAT   TIME COMMAND
1713
Stopping realtime threads
Unloading hal components
libusb: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
libusb: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
*** Error in `xhc-hb04': free(): corrupted unsorted chunks: 0x000055e0521d0aa0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x70bfb)[0x7f10b12eebfb]
/lib/x86_64-linux-gnu/libc.so.6(+0x76fc6)[0x7f10b12f4fc6]
/lib/x86_64-linux-gnu/libc.so.6(+0x7780e)[0x7f10b12f580e]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(+0xb935)[0x7f10b183f935]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_unref_device+0x77)[0x7f10b1838f47]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_exit+0x23c)[0x7f10b183a5dc]
xhc-hb04(+0x2539)[0x55e050628539]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7f10b129e2e1]
xhc-hb04(+0x257a)[0x55e05062857a]
======= Memory map: ========
55e050626000-55e05062b000 r-xp 00000000 08:06 2622966                    /usr/bin/xhc-hb04
55e05082a000-55e05082b000 r--p 00004000 08:06 2622966                    /usr/bin/xhc-hb04
55e05082b000-55e05082c000 rw-p 00005000 08:06 2622966                    /usr/bin/xhc-hb04
55e05082c000-55e05082e000 rw-p 00000000 00:00 0
55e0521a9000-55e0521f9000 rw-p 00000000 00:00 0                          [heap]
7f10ac000000-7f10ac021000 rw-p 00000000 00:00 0
7f10ac021000-7f10b0000000 ---p 00000000 00:00 0
7f10b0658000-7f10b0659000 ---p 00000000 00:00 0
7f10b0659000-7f10b0e59000 rw-p 00000000 00:00 0
7f10b0e59000-7f10b0e71000 r-xp 00000000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b0e71000-7f10b1070000 ---p 00018000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1070000-7f10b1071000 r--p 00017000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1071000-7f10b1072000 rw-p 00018000 08:06 1183086                    /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1072000-7f10b1076000 rw-p 00000000 00:00 0
7f10b1076000-7f10b107d000 r-xp 00000000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b107d000-7f10b127c000 ---p 00007000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127c000-7f10b127d000 r--p 00006000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127d000-7f10b127e000 rw-p 00007000 08:06 1183094                    /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127e000-7f10b1413000 r-xp 00000000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1413000-7f10b1613000 ---p 00195000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1613000-7f10b1617000 r--p 00195000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1617000-7f10b1619000 rw-p 00199000 08:06 1182972                    /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1619000-7f10b161d000 rw-p 00000000 00:00 0
7f10b161d000-7f10b1633000 r-xp 00000000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1633000-7f10b1832000 ---p 00016000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1832000-7f10b1833000 r--p 00015000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1833000-7f10b1834000 rw-p 00016000 08:06 1183003                    /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1834000-7f10b184b000 r-xp 00000000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b184b000-7f10b1a4b000 ---p 00017000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4b000-7f10b1a4c000 r--p 00017000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4c000-7f10b1a4d000 rw-p 00018000 08:06 1183118                    /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4d000-7f10b1bbf000 r-xp 00000000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1bbf000-7f10b1dbf000 ---p 00172000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dbf000-7f10b1dc9000 r--p 00172000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dc9000-7f10b1dcb000 rw-p 0017c000 08:06 2763478                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dcb000-7f10b1dcf000 rw-p 00000000 00:00 0
7f10b1dcf000-7f10b1ed2000 r-xp 00000000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b1ed2000-7f10b20d1000 ---p 00103000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d1000-7f10b20d2000 r--p 00102000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d2000-7f10b20d3000 rw-p 00103000 08:06 1183027                    /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d3000-7f10b20d6000 r-xp 00000000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b20d6000-7f10b22d5000 ---p 00003000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b22d5000-7f10b22d6000 r--p 00002000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b22d6000-7f10b22d7000 rw-p 00003000 08:06 2626705                    /usr/lib/liblinuxcncini.so.0
7f10b22d7000-7f10b22df000 r-xp 00000000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b22df000-7f10b24de000 ---p 00008000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b24de000-7f10b24df000 r--p 00007000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b24df000-7f10b24e0000 rw-p 00008000 08:06 2626703                    /usr/lib/liblinuxcnchal.so.0
7f10b24e0000-7f10b2503000 r-xp 00000000 08:06 1182946                    /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2675000-7f10b26c0000 rw-s 00000000 00:05 1376273                    /SYSV48414c32 (deleted)
7f10b26c0000-7f10b26c5000 rw-p 00000000 00:00 0
7f10b26c5000-7f10b26e4000 r-xp 00000000 08:06 1182831                    /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e4000-7f10b26e5000 r--p 0001e000 08:06 1182831                    /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e5000-7f10b26e6000 rw-p 0001f000 08:06 1182831                    /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e6000-7f10b26e8000 rw-p 00000000 00:00 0
7f10b26fe000-7f10b26ff000 rw-p 00000000 00:00 0
7f10b26ff000-7f10b2700000 rw-s 00000000 00:05 1310736                    /SYSV48484c34 (deleted)
7f10b2700000-7f10b2703000 rw-p 00000000 00:00 0
7f10b2703000-7f10b2704000 r--p 00023000 08:06 1182946                    /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2704000-7f10b2705000 rw-p 00024000 08:06 1182946                    /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2705000-7f10b2706000 rw-p 00000000 00:00 0
7ffcfcd97000-7ffcfcdb8000 rw-p 00000000 00:00 0                          [stack]
7ffcfcde8000-7ffcfcdea000 r--p 00000000 00:00 0                          [vvar]
7ffcfcdea000-7ffcfcdec000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
RTAPI_PCI: Unmapped 65536 bytes at 0x7faad85b5000
Kernel message information:
[    0.000000] Linux version 4.9.0-8-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=282b465a-e193-4032-a698-8fab5f78344b ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000c9d5dfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000c9d5e000-0x00000000c9d64fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000c9d65000-0x00000000ca5a7fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ca5a8000-0x00000000ca7e4fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ca7e5000-0x00000000da38efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da38f000-0x00000000da426fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000da427000-0x00000000da462fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da463000-0x00000000da523fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000da524000-0x00000000daffefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dafff000-0x00000000daffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000db800000-0x00000000df9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. H81-D3/H81-D3, BIOS FC 08/10/2015
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x11f600 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask 7F00000000 write-back
[    0.000000]   1 base 0100000000 mask 7FE0000000 write-back
[    0.000000]   2 base 00E0000000 mask 7FE0000000 uncachable
[    0.000000]   3 base 00DC000000 mask 7FFC000000 uncachable
[    0.000000]   4 base 00DB800000 mask 7FFF800000 uncachable
[    0.000000]   5 base 011F800000 mask 7FFF800000 uncachable
[    0.000000]   6 base 011F600000 mask 7FFFE00000 uncachable
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: update [mem 0xdb800000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0xdb000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fd6e0-0x000fd6ef] mapped at [ffffa0af800fd6e0]
[    0.000000] Base memory trampoline at [ffffa0af80097000] 97000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x106dc0000, 0x106dc0fff] PGTABLE
[    0.000000] BRK [0x106dc1000, 0x106dc1fff] PGTABLE
[    0.000000] BRK [0x106dc2000, 0x106dc2fff] PGTABLE
[    0.000000] BRK [0x106dc3000, 0x106dc3fff] PGTABLE
[    0.000000] BRK [0x106dc4000, 0x106dc4fff] PGTABLE
[    0.000000] BRK [0x106dc5000, 0x106dc5fff] PGTABLE
[    0.000000] BRK [0x106dc6000, 0x106dc6fff] PGTABLE
[    0.000000] BRK [0x106dc7000, 0x106dc7fff] PGTABLE
[    0.000000] BRK [0x106dc8000, 0x106dc8fff] PGTABLE
[    0.000000] BRK [0x106dc9000, 0x106dc9fff] PGTABLE
[    0.000000] BRK [0x106dca000, 0x106dcafff] PGTABLE
[    0.000000] BRK [0x106dcb000, 0x106dcbfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x3521b000-0x36904fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000DA4F1078 00006C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000DA4FD988 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000DA4F1178 00C80C (v02 ALASKA A M I    00000088 INTL 20091112)
[    0.000000] ACPI: FACS 0x00000000DA522080 000040
[    0.000000] ACPI: APIC 0x00000000DA4FDA98 000062 (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x00000000DA4FDB00 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DA4FDB48 000539 (v01 PmRef  Cpu0Ist  00003000 INTL 20120711)
[    0.000000] ACPI: SSDT 0x00000000DA4FE088 000AD8 (v01 PmRef  CpuPm    00003000 INTL 20120711)
[    0.000000] ACPI: MCFG 0x00000000DA4FEB60 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0x00000000DA4FEBA0 000038 (v01 ALASKA A M I    01072009 AMI. 00000005)
[    0.000000] ACPI: SSDT 0x00000000DA4FEBD8 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[    0.000000] ACPI: SSDT 0x00000000DA4FEF48 0034E1 (v01 SaSsdt SaSsdt   00003000 INTL 20091112)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000011f5fffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x11f5fb000-0x11f5fffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000011f5fffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000c9d5dfff]
[    0.000000]   node   0: [mem 0x00000000c9d65000-0x00000000ca5a7fff]
[    0.000000]   node   0: [mem 0x00000000ca7e5000-0x00000000da38efff]
[    0.000000]   node   0: [mem 0x00000000da427000-0x00000000da462fff]
[    0.000000]   node   0: [mem 0x00000000dafff000-0x00000000daffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000011f5fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000011f5fffff]
[    0.000000] On node 0 totalpages: 1021732
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3996 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 13895 pages used for memmap
[    0.000000]   DMA32 zone: 889224 pages, LIFO batch:31
[    0.000000]   Normal zone: 2008 pages used for memmap
[    0.000000]   Normal zone: 128512 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x00000000dba00000-0x00000000df9fffff
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xc9d5e000-0xc9d64fff]
[    0.000000] PM: Registered nosave memory: [mem 0xca5a8000-0xca7e4fff]
[    0.000000] PM: Registered nosave memory: [mem 0xda38f000-0xda426fff]
[    0.000000] PM: Registered nosave memory: [mem 0xda463000-0xda523fff]
[    0.000000] PM: Registered nosave memory: [mem 0xda524000-0xdaffefff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb000000-0xdb7fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb800000-0xdf9fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] percpu: Embedded 116 pages/cpu @ffffa0b09f200000 s437952 r8192 d28992 u1048576
[    0.000000] pcpu-alloc: s437952 r8192 d28992 u1048576 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 1005744
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=282b465a-e193-4032-a698-8fab5f78344b ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 3914704K/4086928K available (6391K kernel code, 1152K rwdata, 2912K rodata, 1680K init, 968K bss, 172224K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS:33024 nr_irqs:440 16
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3092.793 MHz processor
[    0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6185.58 BogoMIPS (lpj=12371172)
[    0.000003] pid_max: default: 32768 minimum: 301
[    0.000011] ACPI: Core revision 20160831
[    0.006765] ACPI: 5 ACPI AML tables successfully acquired and loaded
[    0.006784] Security Framework initialized
[    0.006785] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.006789] AppArmor: AppArmor disabled by boot time parameter
[    0.007180] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
[    0.009027] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.009499] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.009502] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.009733] mce: CPU supports 7 MCE banks
[    0.009741] CPU0: Thermal monitoring enabled (TM1)
[    0.009751] process: using mwait in idle threads
[    0.009753] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[    0.009753] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[    0.009755] Spectre V2 : Mitigation: Full generic retpoline
[    0.009755] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.009755] Speculative Store Bypass: Vulnerable
[    0.010080] Freeing SMP alternatives memory: 24K
[    0.011186] ftrace: allocating 25230 entries in 99 pages
[    0.028378] smpboot: Max logical packages: 1
[    0.028687] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[    0.068375] TSC deadline timer enabled
[    0.068377] smpboot: CPU0: Intel(R) Pentium(R) CPU G3240 @ 3.10GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[    0.068380] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.068397] ... version:                3
[    0.068398] ... bit width:              48
[    0.068398] ... generic registers:      8
[    0.068399] ... value mask:             0000ffffffffffff
[    0.068399] ... max period:             00007fffffffffff
[    0.068400] ... fixed-purpose events:   3
[    0.068400] ... event mask:             00000007000000ff
[    0.124674] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.176863] x86: Booting SMP configuration:
[    0.176864] .... node  #0, CPUs:      #1
[    0.179189] x86: Booted up 1 node, 2 CPUs
[    0.179191] smpboot: Total of 2 processors activated (12371.17 BogoMIPS)
[    0.180554] devtmpfs: initialized
[    0.180617] x86/mm: Memory block size: 128MB
[    0.182067] PM: Registering ACPI NVS region [mem 0xc9d5e000-0xc9d64fff] (28672 bytes)
[    0.182068] PM: Registering ACPI NVS region [mem 0xda463000-0xda523fff] (790528 bytes)
[    0.182113] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.182121] futex hash table entries: 512 (order: 4, 65536 bytes)
[    0.182156] pinctrl core: initialized pinctrl subsystem
[    0.182258] NET: Registered protocol family 16
[    0.187169] cpuidle: using governor ladder
[    0.188905] cpuidle: using governor menu
[    0.188922] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.188923] ACPI: bus type PCI registered
[    0.188924] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.188971] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.188973] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.188977] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.189056] PCI: Using configuration type 1 for base access
[    0.189106] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.189695] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.189785] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[    0.189786] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.189914] ACPI: Added _OSI(Module Device)
[    0.189915] ACPI: Added _OSI(Processor Device)
[    0.189915] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.189916] ACPI: Added _OSI(Processor Aggregator Device)
[    0.190072] ACPI: Executed 1 blocks of module-level executable AML code
[    0.193875] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.194510] ACPI: Dynamic OEM Table Load:
[    0.194514] ACPI: SSDT 0xFFFFA0B099A9A000 0003D3 (v01 PmRef  Cpu0Cst  00003001 INTL 20120711)
[    0.194804] ACPI: Dynamic OEM Table Load:
[    0.194807] ACPI: SSDT 0xFFFFA0B099A92800 0005AA (v01 PmRef  ApIst    00003000 INTL 20120711)
[    0.195099] ACPI: Dynamic OEM Table Load:
[    0.195102] ACPI: SSDT 0xFFFFA0B099A79400 000119 (v01 PmRef  ApCst    00003000 INTL 20120711)
[    0.195773] ACPI: Interpreter enabled
[    0.195795] ACPI: (supports S0 S3 S4 S5)
[    0.195796] ACPI: Using IOAPIC for interrupt routing
[    0.195817] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.202763] ACPI: Power Resource [FN00] (off)
[    0.202825] ACPI: Power Resource [FN01] (off)
[    0.202886] ACPI: Power Resource [FN02] (off)
[    0.202945] ACPI: Power Resource [FN03] (off)
[    0.203002] ACPI: Power Resource [FN04] (off)
[    0.203649] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.203653] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.203826] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[    0.203929] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[    0.203930] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.204228] PCI host bridge to bus 0000:00
[    0.204229] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.204231] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.204232] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.204233] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.204234] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.204235] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.204236] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.204237] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.204238] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.204239] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff window]
[    0.204240] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.204247] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.204322] pci 0000:00:02.0: [8086:0402] type 00 class 0x030000
[    0.204331] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
[    0.204337] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.204341] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.204411] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[    0.204418] pci 0000:00:03.0: reg 0x10: [mem 0xf7e14000-0xf7e17fff 64bit]
[    0.204508] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[    0.204522] pci 0000:00:14.0: reg 0x10: [mem 0xf7e00000-0xf7e0ffff 64bit]
[    0.204576] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.204609] pci 0000:00:14.0: System wakeup disabled by ACPI
[    0.204639] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[    0.204655] pci 0000:00:16.0: reg 0x10: [mem 0xf7e1e000-0xf7e1e00f 64bit]
[    0.204711] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.204778] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[    0.204792] pci 0000:00:1a.0: reg 0x10: [mem 0xf7e1c000-0xf7e1c3ff]
[    0.204868] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.204917] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.204951] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[    0.204965] pci 0000:00:1b.0: reg 0x10: [mem 0xf7e10000-0xf7e13fff 64bit]
[    0.205026] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.205062] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.205092] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[    0.205149] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.205213] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.205245] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[    0.205302] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.205362] pci 0000:00:1c.2: System wakeup disabled by ACPI
[    0.205393] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[    0.205450] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.205509] pci 0000:00:1c.3: System wakeup disabled by ACPI
[    0.205545] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[    0.205560] pci 0000:00:1d.0: reg 0x10: [mem 0xf7e1b000-0xf7e1b3ff]
[    0.205635] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.205678] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.205710] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[    0.205856] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[    0.205868] pci 0000:00:1f.2: reg 0x10: [io  0xf0b0-0xf0b7]
[    0.205874] pci 0000:00:1f.2: reg 0x14: [io  0xf0a0-0xf0a3]
[    0.205880] pci 0000:00:1f.2: reg 0x18: [io  0xf090-0xf097]
[    0.205886] pci 0000:00:1f.2: reg 0x1c: [io  0xf080-0xf083]
[    0.205892] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
[    0.205898] pci 0000:00:1f.2: reg 0x24: [mem 0xf7e1a000-0xf7e1a7ff]
[    0.205929] pci 0000:00:1f.2: PME# supported from D3hot
[    0.205986] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[    0.205999] pci 0000:00:1f.3: reg 0x10: [mem 0xf7e19000-0xf7e190ff 64bit]
[    0.206016] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[    0.206130] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.206197] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.206216] pci 0000:02:00.0: reg 0x10: [io  0xe000-0xe0ff]
[    0.206242] pci 0000:02:00.0: reg 0x18: [mem 0xf7d00000-0xf7d00fff 64bit]
[    0.206259] pci 0000:02:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[    0.206347] pci 0000:02:00.0: supports D1 D2
[    0.206348] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.206390] pci 0000:02:00.0: System wakeup disabled by ACPI
[    0.219249] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.219252] pci 0000:00:1c.2:   bridge window [io  0xe000-0xefff]
[    0.219255] pci 0000:00:1c.2:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.219259] pci 0000:00:1c.2:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.219336] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
[    0.219455] pci 0000:03:00.0: supports D1 D2
[    0.219457] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.219478] pci 0000:03:00.0: System wakeup disabled by ACPI
[    0.219506] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[    0.219510] pci 0000:00:1c.3:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.219567] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[    0.219590] pci 0000:04:00.0: reg 0x10: [mem 0xf7c00000-0xf7c0ffff]
[    0.219793] pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode)
[    0.219806] pci 0000:03:00.0:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.219815] pci 0000:03:00.0:   bridge window [mem 0xf7c00000-0xf7cfffff] (subtractive decode)
[    0.220527] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.220564] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.220600] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.220636] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.220671] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.220710] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.220748] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.220783] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.221032] ACPI: Enabled 4 GPEs in block 00 to 3F
[    0.221130] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.221132] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.221136] vgaarb: loaded
[    0.221136] vgaarb: bridge control possible 0000:00:02.0
[    0.221198] PCI: Using ACPI for IRQ routing
[    0.222452] PCI: pci_cache_line_size set to 64 bytes
[    0.222494] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[    0.222496] e820: reserve RAM buffer [mem 0xc9d5e000-0xcbffffff]
[    0.222497] e820: reserve RAM buffer [mem 0xca5a8000-0xcbffffff]
[    0.222497] e820: reserve RAM buffer [mem 0xda38f000-0xdbffffff]
[    0.222498] e820: reserve RAM buffer [mem 0xda463000-0xdbffffff]
[    0.222499] e820: reserve RAM buffer [mem 0xdb000000-0xdbffffff]
[    0.222500] e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff]
[    0.222618] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.222623] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.224638] clocksource: Switched to clocksource hpet
[    0.232435] VFS: Disk quotas dquot_6.6.0
[    0.232454] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.232534] pnp: PnP ACPI init
[    0.232667] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.232671] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.232812] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.232813] system 00:01: [io  0xffff] has been reserved
[    0.232815] system 00:01: [io  0xffff] has been reserved
[    0.232816] system 00:01: [io  0xffff] has been reserved
[    0.232817] system 00:01: [io  0x1c00-0x1cfe] has been reserved
[    0.232818] system 00:01: [io  0x1d00-0x1dfe] has been reserved
[    0.232820] system 00:01: [io  0x1e00-0x1efe] has been reserved
[    0.232821] system 00:01: [io  0x1f00-0x1ffe] has been reserved
[    0.232822] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.232823] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.232825] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.232847] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.232888] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.232890] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.232991] system 00:04: [io  0x0a00-0x0a0f] has been reserved
[    0.232992] system 00:04: [io  0x0a30-0x0a3f] has been reserved
[    0.232993] system 00:04: [io  0x0a20-0x0a2f] has been reserved
[    0.232995] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.233029] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[    0.233212] pnp 00:06: [dma 0 disabled]
[    0.233249] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.233469] pnp 00:07: [dma 0 disabled]
[    0.233560] pnp 00:07: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.233602] system 00:08: [io  0x04d0-0x04d1] has been reserved
[    0.233604] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.233931] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.233933] system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.233934] system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.233935] system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.233937] system 00:09: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.233938] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.233939] system 00:09: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.233940] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.233942] system 00:09: [mem 0xff000000-0xffffffff] has been reserved
[    0.233943] system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.233945] system 00:09: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[    0.233946] system 00:09: [mem 0xf7fe0000-0xf7feffff] has been reserved
[    0.233948] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.234111] pnp: PnP ACPI: found 10 devices
[    0.240128] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.240162] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.240171] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.240173] pci 0000:00:1c.2:   bridge window [io  0xe000-0xefff]
[    0.240177] pci 0000:00:1c.2:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.240179] pci 0000:00:1c.2:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.240184] pci 0000:03:00.0: PCI bridge to [bus 04]
[    0.240191] pci 0000:03:00.0:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.240204] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[    0.240208] pci 0000:00:1c.3:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.240214] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.240216] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.240217] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.240218] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.240219] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.240220] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.240221] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.240223] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[    0.240224] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
[    0.240225] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff window]
[    0.240226] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[    0.240227] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
[    0.240228] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.240229] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.240230] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.240231] pci_bus 0000:04: resource 4 [mem 0xf7c00000-0xf7cfffff]
[    0.240308] NET: Registered protocol family 2
[    0.240436] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.240599] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes)
[    0.240981] TCP: Hash tables configured (established 32768 bind 32768)
[    0.241016] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[    0.241084] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[    0.241180] NET: Registered protocol family 1
[    0.241191] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.288748] PCI: CLS 64 bytes, default 64
[    0.288795] Unpacking initramfs...
[    0.584563] Freeing initrd memory: 23464K
[    0.584566] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.584568] software IO TLB [mem 0xd638f000-0xda38f000] (64MB) mapped at [ffffa0b05638f000-ffffa0b05a38efff]
[    0.584863] audit: initializing netlink subsys (disabled)
[    0.584879] audit: type=2000 audit(1546955512.584:1): initialized
[    0.585227] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[    0.586550] zbud: loaded
[    0.587266] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.587292] io scheduler noop registered
[    0.587293] io scheduler deadline registered
[    0.587319] io scheduler cfq registered (default)
[    0.587728] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.587732] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.587747] intel_idle: MWAIT substates: 0x2120
[    0.587748] intel_idle: v0.4.1 model 0x3C
[    0.587802] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.587899] GHES: HEST is not enabled!
[    0.587949] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.608369] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.608860] Linux agpgart interface v0.103
[    0.608946] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.608946] AMD IOMMUv2 functionality not available on this system
[    0.609098] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    0.609098] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    0.609267] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.609365] mousedev: PS/2 mouse device common for all mice
[    0.609400] rtc_cmos 00:02: RTC can wake from S4
[    0.609512] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    0.609574] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.609583] intel_pstate: Intel P-state driver initializing
[    0.611227] NET: Registered protocol family 10
[    0.611855] mip6: Mobile IPv6
[    0.611861] NET: Registered protocol family 17
[    0.611868] mpls_gso: MPLS GSO support
[    0.612258] microcode: sig=0x306c3, pf=0x2, revision=0x19
[    0.612367] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    0.612791] registered taskstats version 1
[    0.612841] zswap: loaded using pool lzo/zbud
[    0.612957] ima: No TPM chip found, activating TPM-bypass!
[    0.612961] ima: Allocated hash algorithm: sha256
[    0.613904] rtc_cmos 00:02: setting system clock to 2019-01-08 13:51:52 UTC (1546955512)
[    0.614082] PM: Hibernation image not present or could not be loaded.
[    0.617033] Freeing unused kernel memory: 1680K
[    0.617035] Write protecting the kernel read-only data: 12288k
[    0.618754] Freeing unused kernel memory: 1784K
[    0.625605] Freeing unused kernel memory: 1184K
[    0.629468] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    0.638034] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.666547] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.666681] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.666700] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.727731] thermal LNXTHERM:00: registered as thermal_zone0
[    0.727734] ACPI: Thermal Zone [TZ00] (28 C)
[    0.728228] thermal LNXTHERM:01: registered as thermal_zone1
[    0.728230] ACPI: Thermal Zone [TZ01] (30 C)
[    0.734816] ACPI: bus type USB registered
[    0.734843] usbcore: registered new interface driver usbfs
[    0.734856] usbcore: registered new interface driver hub
[    0.735227] usbcore: registered new device driver usb
[    0.735769] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.735981] ehci-pci: EHCI PCI platform driver
[    0.736178] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.736188] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.736201] ehci-pci 0000:00:1a.0: debug port 2
[    0.737821] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    0.737829] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    0.740102] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    0.740165] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7e1c000
[    0.741099] SCSI subsystem initialized
[    0.749606] r8169 0000:02:00.0 eth0: RTL8168g/8111g at 0xffffb51dc0a7d000, 40:8d:5c:81:32:43, XID 0c000800 IRQ 24
[    0.749609] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    0.752087] libata version 3.00 loaded.
[    0.752693] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.752919] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.752921] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.752923] usb usb1: Product: EHCI Host Controller
[    0.752924] usb usb1: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[    0.752926] usb usb1: SerialNumber: 0000:00:1a.0
[    0.763213] hub 1-0:1.0: USB hub found
[    0.763225] hub 1-0:1.0: 2 ports detected
[    0.763533] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.763538] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.764617] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[    0.764622] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.766170] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.766172] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.766174] usb usb2: Product: xHCI Host Controller
[    0.766175] usb usb2: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[    0.766177] usb usb2: SerialNumber: 0000:00:14.0
[    0.768280] hub 2-0:1.0: USB hub found
[    0.768297] hub 2-0:1.0: 10 ports detected
[    0.772910] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.772914] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    0.772955] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[    0.772957] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.772958] usb usb3: Product: xHCI Host Controller
[    0.772960] usb usb3: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[    0.772961] usb usb3: SerialNumber: 0000:00:14.0
[    0.773168] hub 3-0:1.0: USB hub found
[    0.773176] hub 3-0:1.0: 2 ports detected
[    0.773405] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[    0.773535] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[    0.773589] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    0.774479] ahci 0000:00:1f.2: version 3.0
[    0.774655] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x1 impl SATA mode
[    0.774658] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems
[    0.779170] scsi host0: ahci
[    0.779286] scsi host1: ahci
[    0.779383] scsi host2: ahci
[    0.779481] scsi host3: ahci
[    0.779531] ata1: SATA max UDMA/133 abar m2048@0xf7e1a000 port 0xf7e1a100 irq 26
[    0.779533] ata2: DUMMY
[    0.779533] ata3: DUMMY
[    0.779534] ata4: DUMMY
[    0.779761] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.779766] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[    0.779776] ehci-pci 0000:00:1d.0: debug port 2
[    0.783680] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    0.783718] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7e1b000
[    0.796701] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.797160] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    0.797162] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.797163] usb usb4: Product: EHCI Host Controller
[    0.797164] usb usb4: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[    0.797165] usb usb4: SerialNumber: 0000:00:1d.0
[    0.797396] hub 4-0:1.0: USB hub found
[    0.797403] hub 4-0:1.0: 2 ports detected
[    1.088744] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.100274] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.100696] usb 2-4: new full-speed USB device number 2 using xhci_hcd
[    1.100858] ata1.00: ATA-9: C300-MTFDBAK128MAG, 0308, max UDMA/100
[    1.100862] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.101634] ata1.00: configured for UDMA/100
[    1.102054] scsi 0:0:0:0: Direct-Access     ATA      C300-MTFDBAK128M 0308 PQ: 0 ANSI: 5
[    1.124724] usb 4-1: new high-speed USB device number 2 using ehci-pci
[    1.136347] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[    1.136432] sd 0:0:0:0: [sda] Write Protect is off
[    1.136435] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.136455] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.137062]  sda: sda1 sda2 < sda5 sda6 >
[    1.137535] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.192379] PM: Starting manual resume from disk
[    1.192382] PM: Hibernation image partition 8:5 present
[    1.192383] PM: Looking for hibernation image.
[    1.192544] PM: Image not found (code -22)
[    1.192545] PM: Hibernation image not present or could not be loaded.
[    1.237111] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[    1.237113] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.237401] hub 1-1:1.0: USB hub found
[    1.237485] hub 1-1:1.0: 4 ports detected
[    1.241506] usb 2-4: New USB device found, idVendor=1a86, idProduct=7523
[    1.241508] usb 2-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    1.241509] usb 2-4: Product: USB2.0-Serial
[    1.273091] usb 4-1: New USB device found, idVendor=8087, idProduct=8000
[    1.273094] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.273242] hub 4-1:1.0: USB hub found
[    1.273339] hub 4-1:1.0: 6 ports detected
[    1.297450] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[    1.298305] random: fast init done
[    1.360694] usb 2-5: new low-speed USB device number 3 using xhci_hcd
[    1.384133] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.388704] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    1.388806] systemd[1]: Detected architecture x86-64.
[    1.388964] systemd[1]: Set hostname to <cnc-debian>.
[    1.440097] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    1.440110] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    1.440582] systemd[1]: Listening on udev Control Socket.
[    1.440724] systemd[1]: Listening on Journal Audit Socket.
[    1.440761] systemd[1]: Listening on Syslog Socket.
[    1.440910] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.440940] systemd[1]: Listening on udev Kernel Socket.
[    1.465272] lp: driver loaded but no devices found
[    1.466729] ppdev: user-space parallel port driver
[    1.467417] parport_pc 00:07: reported by Plug and Play ACPI
[    1.467485] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[    1.471549] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[    1.505521] usb 2-5: New USB device found, idVendor=046d, idProduct=c408
[    1.505523] usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.505524] usb 2-5: Product: USB Trackball
[    1.505525] usb 2-5: Manufacturer: Logitech
[    1.569004] lp0: using parport0 (interrupt-driven).
[    1.600682] tsc: Refined TSC clocksource calibration: 3092.838 MHz
[    1.600687] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c94d9afcf4, max_idle_ns: 440795231738 ns
[    1.628685] usb 2-6: new full-speed USB device number 4 using xhci_hcd
[    1.669450] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    1.669454] ACPI: Power Button [PWRB]
[    1.670564] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    1.670566] ACPI: Power Button [PWRF]
[    1.701435] systemd-journald[201]: Received request to flush runtime journal from PID 1
[    1.769609] usb 2-6: New USB device found, idVendor=10ce, idProduct=eb70
[    1.769612] usb 2-6: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[    1.769613] usb 2-6: Manufacturer: KTURT.LTD
[    1.860206] hidraw: raw HID events driver (C) Jiri Kosina
[    1.877436] usbcore: registered new interface driver usbhid
[    1.877438] usbhid: USB HID core driver
[    1.913036] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.926275] [drm] Initialized
[    1.972222] [drm] PipeC fused off
[    1.972232] [drm] Memory usable by graphics device = 2048M
[    1.972234] [drm] Replacing VGA console driver
[    1.976290] Console: switching to colour dummy device 80x25
[    1.983827] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.983828] [drm] Driver supports precise vblank timestamp query.
[    2.001984] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.038511] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    2.043798] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[    2.048573] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    2.048579] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    2.049258] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.050225] snd_hda_codec_realtek hdaudioC1D2: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    2.050227] snd_hda_codec_realtek hdaudioC1D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.050228] snd_hda_codec_realtek hdaudioC1D2:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    2.050229] snd_hda_codec_realtek hdaudioC1D2:    mono: mono_out=0x0
[    2.050230] snd_hda_codec_realtek hdaudioC1D2:    dig-out=0x11/0x0
[    2.050231] snd_hda_codec_realtek hdaudioC1D2:    inputs:
[    2.050233] snd_hda_codec_realtek hdaudioC1D2:      Rear Mic=0x18
[    2.050234] snd_hda_codec_realtek hdaudioC1D2:      Front Mic=0x19
[    2.050235] snd_hda_codec_realtek hdaudioC1D2:      Line=0x1a
[    2.050236] snd_hda_codec_realtek hdaudioC1D2:      CD=0x1c
[    2.053802] input: PC Speaker as /devices/platform/pcspkr/input/input4
[    2.062595] fbcon: inteldrmfb (fb0) is primary device
[    2.070847] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card1/input5
[    2.086566] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input6
[    2.095617] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input7
[    2.096777] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    2.096777] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    2.096778] RAPL PMU: hw unit of domain package 2^-14 Joules
[    2.096778] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    2.096778] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    2.100242] usbcore: registered new interface driver usbserial
[    2.100565] usbcore: registered new interface driver usbserial_generic
[    2.100969] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input8
[    2.101083] usbserial: USB Serial support registered for generic
[    2.103925] usbcore: registered new interface driver ch341
[    2.104328] usbserial: USB Serial support registered for ch341-uart
[    2.104430] ch341 2-4:1.0: ch341-uart converter detected
[    2.104518] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input9
[    2.107404] usb 2-4: ch341-uart converter now attached to ttyUSB0
[    2.124064] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input10
[    2.127786] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input11
[    2.131838] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input12
[    2.140744] Console: switching to colour frame buffer device 210x65
[    2.159125] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    2.178852] input: Logitech USB Trackball as /devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/0003:046D:C408.0001/input/input13
[    2.178941] hid-generic 0003:046D:C408.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Trackball] on usb-0000:00:14.0-5/input0
[    2.179392] hid-generic 0003:10CE:EB70.0002: hiddev0,hidraw1: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:14.0-6/input0
[    2.180056] Adding 4085756k swap on /dev/sda5.  Priority:-1 extents:1 across:4085756k SSFS
[    2.219728] intel_rapl: Found RAPL domain package
[    2.219729] intel_rapl: Found RAPL domain core
[    2.219730] intel_rapl: Found RAPL domain uncore
[    2.219730] intel_rapl: Found RAPL domain dram
[    2.236106] iTCO_vendor_support: vendor-support=0
[    2.242191] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    2.242477] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[    2.628721] clocksource: Switched to clocksource tsc
[    2.646836] r8169 0000:02:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[    2.719040] r8169 0000:02:00.0 eth0: link down
[    2.719045] r8169 0000:02:00.0 eth0: link down
[    2.719119] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.166113] r8169 0000:02:00.0 eth0: link up
[    5.166130] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.138465] random: crng init done
[   13.138467] random: 7 urandom warning(s) missed due to ratelimiting
(bericht werd te groot...)
Beginnen met CNC?
Bericht door DaBit » 08 jan 2019 15:14
Ik heb destijds in jouw /etc/udev/rules.d directory een rule(bestandje) geplaatst die de RS485 adapter altijd aanmaakt als /dev/spindelregeling met de juiste permissies.
Die rule moet je even opzoeken en kopieren naar je nieuwe installatie op dezelfde plek. Dan overnieuw opstarten of 'sudo udevadm control --reload-rules' intikken.
Bericht door Sven » 08 jan 2019 15:35
Dawassum, doetutnu!
Dank voor je snelle reactie!
Er staan nog 3 andere rules in die map, moeten die ook mee?
In debian stonden er geen in die map toen ik begon.
Beginnen met CNC?
Bericht door DaBit » 08 jan 2019 17:43
welke zijn die anderen?
Bericht door Sven » 08 jan 2019 19:14
Ga ik nakijken als ik weer in de werkplaats ben maar eentje was iets met RTAI, dat lijkt me niet voor debian?
Beginnen met CNC?
Bericht door Sven » 11 jan 2019 12:56
DaBit schreef:
08 jan 2019 17:43
70-persistent-cd.rules
70-persistent-net.rules
99-rtai.rules
README
Beginnen met CNC?
javanree
Bericht door javanree » 11 jan 2019 14:09
RTAI is niet van toepassing als je een Mesa kaart draait, dan heb je immers geen RTAI maar preempt-rt kernel.
persistent-cd en persistent-net zijn system dingen, moet je zeker niet zelf gaan copieeren / editen.
Bericht door Sven » 11 jan 2019 21:50
Prima, ik blijf er vanaf, dank!
Beginnen met CNC?
