Debug file information:
pickconfig: installed aux examples: /usr/share/linuxcnc/aux_examples/NativeCAM
./Alu-XYZA.hal:4: Warning: File contains DOS-style line endings.
Note: Using POSIX realtime
xhc-hb04.tcl: using std_start_pause_button
Can not find -sec APPLICATIONS -var DELAY -num 1
open: No such file or directory
custom_postgui.hal:6: waitpid failed hy_vfd vfd
custom_postgui.hal:6: hy_vfd exited without becoming ready
1675
PID TTY STAT TIME COMMAND
1713
Stopping realtime threads
Unloading hal components
libusb: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
libusb: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
*** Error in `xhc-hb04': free(): corrupted unsorted chunks: 0x000055e0521d0aa0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x70bfb)[0x7f10b12eebfb]
/lib/x86_64-linux-gnu/libc.so.6(+0x76fc6)[0x7f10b12f4fc6]
/lib/x86_64-linux-gnu/libc.so.6(+0x7780e)[0x7f10b12f580e]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(+0xb935)[0x7f10b183f935]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_unref_device+0x77)[0x7f10b1838f47]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_exit+0x23c)[0x7f10b183a5dc]
xhc-hb04(+0x2539)[0x55e050628539]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7f10b129e2e1]
xhc-hb04(+0x257a)[0x55e05062857a]
======= Memory map: ========
55e050626000-55e05062b000 r-xp 00000000 08:06 2622966 /usr/bin/xhc-hb04
55e05082a000-55e05082b000 r--p 00004000 08:06 2622966 /usr/bin/xhc-hb04
55e05082b000-55e05082c000 rw-p 00005000 08:06 2622966 /usr/bin/xhc-hb04
55e05082c000-55e05082e000 rw-p 00000000 00:00 0
55e0521a9000-55e0521f9000 rw-p 00000000 00:00 0 [heap]
7f10ac000000-7f10ac021000 rw-p 00000000 00:00 0
7f10ac021000-7f10b0000000 ---p 00000000 00:00 0
7f10b0658000-7f10b0659000 ---p 00000000 00:00 0
7f10b0659000-7f10b0e59000 rw-p 00000000 00:00 0
7f10b0e59000-7f10b0e71000 r-xp 00000000 08:06 1183086 /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b0e71000-7f10b1070000 ---p 00018000 08:06 1183086 /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1070000-7f10b1071000 r--p 00017000 08:06 1183086 /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1071000-7f10b1072000 rw-p 00018000 08:06 1183086 /lib/x86_64-linux-gnu/libpthread-2.24.so
7f10b1072000-7f10b1076000 rw-p 00000000 00:00 0
7f10b1076000-7f10b107d000 r-xp 00000000 08:06 1183094 /lib/x86_64-linux-gnu/librt-2.24.so
7f10b107d000-7f10b127c000 ---p 00007000 08:06 1183094 /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127c000-7f10b127d000 r--p 00006000 08:06 1183094 /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127d000-7f10b127e000 rw-p 00007000 08:06 1183094 /lib/x86_64-linux-gnu/librt-2.24.so
7f10b127e000-7f10b1413000 r-xp 00000000 08:06 1182972 /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1413000-7f10b1613000 ---p 00195000 08:06 1182972 /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1613000-7f10b1617000 r--p 00195000 08:06 1182972 /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1617000-7f10b1619000 rw-p 00199000 08:06 1182972 /lib/x86_64-linux-gnu/libc-2.24.so
7f10b1619000-7f10b161d000 rw-p 00000000 00:00 0
7f10b161d000-7f10b1633000 r-xp 00000000 08:06 1183003 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1633000-7f10b1832000 ---p 00016000 08:06 1183003 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1832000-7f10b1833000 r--p 00015000 08:06 1183003 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1833000-7f10b1834000 rw-p 00016000 08:06 1183003 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f10b1834000-7f10b184b000 r-xp 00000000 08:06 1183118 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b184b000-7f10b1a4b000 ---p 00017000 08:06 1183118 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4b000-7f10b1a4c000 r--p 00017000 08:06 1183118 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4c000-7f10b1a4d000 rw-p 00018000 08:06 1183118 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f10b1a4d000-7f10b1bbf000 r-xp 00000000 08:06 2763478 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1bbf000-7f10b1dbf000 ---p 00172000 08:06 2763478 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dbf000-7f10b1dc9000 r--p 00172000 08:06 2763478 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dc9000-7f10b1dcb000 rw-p 0017c000 08:06 2763478 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
7f10b1dcb000-7f10b1dcf000 rw-p 00000000 00:00 0
7f10b1dcf000-7f10b1ed2000 r-xp 00000000 08:06 1183027 /lib/x86_64-linux-gnu/libm-2.24.so
7f10b1ed2000-7f10b20d1000 ---p 00103000 08:06 1183027 /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d1000-7f10b20d2000 r--p 00102000 08:06 1183027 /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d2000-7f10b20d3000 rw-p 00103000 08:06 1183027 /lib/x86_64-linux-gnu/libm-2.24.so
7f10b20d3000-7f10b20d6000 r-xp 00000000 08:06 2626705 /usr/lib/liblinuxcncini.so.0
7f10b20d6000-7f10b22d5000 ---p 00003000 08:06 2626705 /usr/lib/liblinuxcncini.so.0
7f10b22d5000-7f10b22d6000 r--p 00002000 08:06 2626705 /usr/lib/liblinuxcncini.so.0
7f10b22d6000-7f10b22d7000 rw-p 00003000 08:06 2626705 /usr/lib/liblinuxcncini.so.0
7f10b22d7000-7f10b22df000 r-xp 00000000 08:06 2626703 /usr/lib/liblinuxcnchal.so.0
7f10b22df000-7f10b24de000 ---p 00008000 08:06 2626703 /usr/lib/liblinuxcnchal.so.0
7f10b24de000-7f10b24df000 r--p 00007000 08:06 2626703 /usr/lib/liblinuxcnchal.so.0
7f10b24df000-7f10b24e0000 rw-p 00008000 08:06 2626703 /usr/lib/liblinuxcnchal.so.0
7f10b24e0000-7f10b2503000 r-xp 00000000 08:06 1182946 /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2675000-7f10b26c0000 rw-s 00000000 00:05 1376273 /SYSV48414c32 (deleted)
7f10b26c0000-7f10b26c5000 rw-p 00000000 00:00 0
7f10b26c5000-7f10b26e4000 r-xp 00000000 08:06 1182831 /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e4000-7f10b26e5000 r--p 0001e000 08:06 1182831 /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e5000-7f10b26e6000 rw-p 0001f000 08:06 1182831 /lib/x86_64-linux-gnu/libudev.so.1.6.5
7f10b26e6000-7f10b26e8000 rw-p 00000000 00:00 0
7f10b26fe000-7f10b26ff000 rw-p 00000000 00:00 0
7f10b26ff000-7f10b2700000 rw-s 00000000 00:05 1310736 /SYSV48484c34 (deleted)
7f10b2700000-7f10b2703000 rw-p 00000000 00:00 0
7f10b2703000-7f10b2704000 r--p 00023000 08:06 1182946 /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2704000-7f10b2705000 rw-p 00024000 08:06 1182946 /lib/x86_64-linux-gnu/ld-2.24.so
7f10b2705000-7f10b2706000 rw-p 00000000 00:00 0
7ffcfcd97000-7ffcfcdb8000 rw-p 00000000 00:00 0 [stack]
7ffcfcde8000-7ffcfcdea000 r--p 00000000 00:00 0 [vvar]
7ffcfcdea000-7ffcfcdec000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
RTAPI_PCI: Unmapped 65536 bytes at 0x7faad85b5000
Kernel message information:
[ 0.000000] Linux version 4.9.0-8-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=282b465a-e193-4032-a698-8fab5f78344b ro quiet
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000c9d5dfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c9d5e000-0x00000000c9d64fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000c9d65000-0x00000000ca5a7fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ca5a8000-0x00000000ca7e4fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ca7e5000-0x00000000da38efff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000da38f000-0x00000000da426fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000da427000-0x00000000da462fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000da463000-0x00000000da523fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000da524000-0x00000000daffefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dafff000-0x00000000daffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000db800000-0x00000000df9fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. H81-D3/H81-D3, BIOS FC 08/10/2015
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x11f600 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7F00000000 write-back
[ 0.000000] 1 base 0100000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00DC000000 mask 7FFC000000 uncachable
[ 0.000000] 4 base 00DB800000 mask 7FFF800000 uncachable
[ 0.000000] 5 base 011F800000 mask 7FFF800000 uncachable
[ 0.000000] 6 base 011F600000 mask 7FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] e820: update [mem 0xdb800000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xdb000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fd6e0-0x000fd6ef] mapped at [ffffa0af800fd6e0]
[ 0.000000] Base memory trampoline at [ffffa0af80097000] 97000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] BRK [0x106dc0000, 0x106dc0fff] PGTABLE
[ 0.000000] BRK [0x106dc1000, 0x106dc1fff] PGTABLE
[ 0.000000] BRK [0x106dc2000, 0x106dc2fff] PGTABLE
[ 0.000000] BRK [0x106dc3000, 0x106dc3fff] PGTABLE
[ 0.000000] BRK [0x106dc4000, 0x106dc4fff] PGTABLE
[ 0.000000] BRK [0x106dc5000, 0x106dc5fff] PGTABLE
[ 0.000000] BRK [0x106dc6000, 0x106dc6fff] PGTABLE
[ 0.000000] BRK [0x106dc7000, 0x106dc7fff] PGTABLE
[ 0.000000] BRK [0x106dc8000, 0x106dc8fff] PGTABLE
[ 0.000000] BRK [0x106dc9000, 0x106dc9fff] PGTABLE
[ 0.000000] BRK [0x106dca000, 0x106dcafff] PGTABLE
[ 0.000000] BRK [0x106dcb000, 0x106dcbfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x3521b000-0x36904fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000DA4F1078 00006C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000DA4FD988 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000DA4F1178 00C80C (v02 ALASKA A M I 00000088 INTL 20091112)
[ 0.000000] ACPI: FACS 0x00000000DA522080 000040
[ 0.000000] ACPI: APIC 0x00000000DA4FDA98 000062 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000DA4FDB00 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000DA4FDB48 000539 (v01 PmRef Cpu0Ist 00003000 INTL 20120711)
[ 0.000000] ACPI: SSDT 0x00000000DA4FE088 000AD8 (v01 PmRef CpuPm 00003000 INTL 20120711)
[ 0.000000] ACPI: MCFG 0x00000000DA4FEB60 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000DA4FEBA0 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 0x00000000DA4FEBD8 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.000000] ACPI: SSDT 0x00000000DA4FEF48 0034E1 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000011f5fffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x11f5fb000-0x11f5fffff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000011f5fffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000c9d5dfff]
[ 0.000000] node 0: [mem 0x00000000c9d65000-0x00000000ca5a7fff]
[ 0.000000] node 0: [mem 0x00000000ca7e5000-0x00000000da38efff]
[ 0.000000] node 0: [mem 0x00000000da427000-0x00000000da462fff]
[ 0.000000] node 0: [mem 0x00000000dafff000-0x00000000daffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000011f5fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000011f5fffff]
[ 0.000000] On node 0 totalpages: 1021732
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3996 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 13895 pages used for memmap
[ 0.000000] DMA32 zone: 889224 pages, LIFO batch:31
[ 0.000000] Normal zone: 2008 pages used for memmap
[ 0.000000] Normal zone: 128512 pages, LIFO batch:31
[ 0.000000] Reserving Intel graphics memory at 0x00000000dba00000-0x00000000df9fffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xc9d5e000-0xc9d64fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca5a8000-0xca7e4fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xda38f000-0xda426fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xda463000-0xda523fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xda524000-0xdaffefff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdb000000-0xdb7fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdb800000-0xdf9fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] e820: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] percpu: Embedded 116 pages/cpu @ffffa0b09f200000 s437952 r8192 d28992 u1048576
[ 0.000000] pcpu-alloc: s437952 r8192 d28992 u1048576 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1005744
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=282b465a-e193-4032-a698-8fab5f78344b ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 3914704K/4086928K available (6391K kernel code, 1152K rwdata, 2912K rodata, 1680K init, 968K bss, 172224K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Kernel/User page tables isolation: enabled
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:33024 nr_irqs:440 16
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3092.793 MHz processor
[ 0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6185.58 BogoMIPS (lpj=12371172)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000011] ACPI: Core revision 20160831
[ 0.006765] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.006784] Security Framework initialized
[ 0.006785] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.006789] AppArmor: AppArmor disabled by boot time parameter
[ 0.007180] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.009027] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.009499] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.009502] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.009733] mce: CPU supports 7 MCE banks
[ 0.009741] CPU0: Thermal monitoring enabled (TM1)
[ 0.009751] process: using mwait in idle threads
[ 0.009753] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[ 0.009753] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[ 0.009755] Spectre V2 : Mitigation: Full generic retpoline
[ 0.009755] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.009755] Speculative Store Bypass: Vulnerable
[ 0.010080] Freeing SMP alternatives memory: 24K
[ 0.011186] ftrace: allocating 25230 entries in 99 pages
[ 0.028378] smpboot: Max logical packages: 1
[ 0.028687] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.068375] TSC deadline timer enabled
[ 0.068377] smpboot: CPU0: Intel(R) Pentium(R) CPU G3240 @ 3.10GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[ 0.068380] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.068397] ... version: 3
[ 0.068398] ... bit width: 48
[ 0.068398] ... generic registers: 8
[ 0.068399] ... value mask: 0000ffffffffffff
[ 0.068399] ... max period: 00007fffffffffff
[ 0.068400] ... fixed-purpose events: 3
[ 0.068400] ... event mask: 00000007000000ff
[ 0.124674] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.176863] x86: Booting SMP configuration:
[ 0.176864] .... node #0, CPUs: #1
[ 0.179189] x86: Booted up 1 node, 2 CPUs
[ 0.179191] smpboot: Total of 2 processors activated (12371.17 BogoMIPS)
[ 0.180554] devtmpfs: initialized
[ 0.180617] x86/mm: Memory block size: 128MB
[ 0.182067] PM: Registering ACPI NVS region [mem 0xc9d5e000-0xc9d64fff] (28672 bytes)
[ 0.182068] PM: Registering ACPI NVS region [mem 0xda463000-0xda523fff] (790528 bytes)
[ 0.182113] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.182121] futex hash table entries: 512 (order: 4, 65536 bytes)
[ 0.182156] pinctrl core: initialized pinctrl subsystem
[ 0.182258] NET: Registered protocol family 16
[ 0.187169] cpuidle: using governor ladder
[ 0.188905] cpuidle: using governor menu
[ 0.188922] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.188923] ACPI: bus type PCI registered
[ 0.188924] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.188971] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.188973] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.188977] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[ 0.189056] PCI: Using configuration type 1 for base access
[ 0.189106] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[ 0.189695] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.189785] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[ 0.189786] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.189914] ACPI: Added _OSI(Module Device)
[ 0.189915] ACPI: Added _OSI(Processor Device)
[ 0.189915] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.189916] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.190072] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.193875] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.194510] ACPI: Dynamic OEM Table Load:
[ 0.194514] ACPI: SSDT 0xFFFFA0B099A9A000 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711)
[ 0.194804] ACPI: Dynamic OEM Table Load:
[ 0.194807] ACPI: SSDT 0xFFFFA0B099A92800 0005AA (v01 PmRef ApIst 00003000 INTL 20120711)
[ 0.195099] ACPI: Dynamic OEM Table Load:
[ 0.195102] ACPI: SSDT 0xFFFFA0B099A79400 000119 (v01 PmRef ApCst 00003000 INTL 20120711)
[ 0.195773] ACPI: Interpreter enabled
[ 0.195795] ACPI: (supports S0 S3 S4 S5)
[ 0.195796] ACPI: Using IOAPIC for interrupt routing
[ 0.195817] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.202763] ACPI: Power Resource [FN00] (off)
[ 0.202825] ACPI: Power Resource [FN01] (off)
[ 0.202886] ACPI: Power Resource [FN02] (off)
[ 0.202945] ACPI: Power Resource [FN03] (off)
[ 0.203002] ACPI: Power Resource [FN04] (off)
[ 0.203649] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.203653] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.203826] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[ 0.203929] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.203930] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.204228] PCI host bridge to bus 0000:00
[ 0.204229] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.204231] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.204232] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.204233] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.204234] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.204235] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.204236] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.204237] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.204238] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.204239] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff window]
[ 0.204240] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.204247] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.204322] pci 0000:00:02.0: [8086:0402] type 00 class 0x030000
[ 0.204331] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.204337] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.204341] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.204411] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[ 0.204418] pci 0000:00:03.0: reg 0x10: [mem 0xf7e14000-0xf7e17fff 64bit]
[ 0.204508] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[ 0.204522] pci 0000:00:14.0: reg 0x10: [mem 0xf7e00000-0xf7e0ffff 64bit]
[ 0.204576] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.204609] pci 0000:00:14.0: System wakeup disabled by ACPI
[ 0.204639] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[ 0.204655] pci 0000:00:16.0: reg 0x10: [mem 0xf7e1e000-0xf7e1e00f 64bit]
[ 0.204711] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.204778] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[ 0.204792] pci 0000:00:1a.0: reg 0x10: [mem 0xf7e1c000-0xf7e1c3ff]
[ 0.204868] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.204917] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.204951] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[ 0.204965] pci 0000:00:1b.0: reg 0x10: [mem 0xf7e10000-0xf7e13fff 64bit]
[ 0.205026] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.205062] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.205092] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[ 0.205149] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.205213] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.205245] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[ 0.205302] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.205362] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.205393] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[ 0.205450] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.205509] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.205545] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[ 0.205560] pci 0000:00:1d.0: reg 0x10: [mem 0xf7e1b000-0xf7e1b3ff]
[ 0.205635] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.205678] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.205710] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[ 0.205856] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[ 0.205868] pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7]
[ 0.205874] pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3]
[ 0.205880] pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097]
[ 0.205886] pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083]
[ 0.205892] pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
[ 0.205898] pci 0000:00:1f.2: reg 0x24: [mem 0xf7e1a000-0xf7e1a7ff]
[ 0.205929] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.205986] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[ 0.205999] pci 0000:00:1f.3: reg 0x10: [mem 0xf7e19000-0xf7e190ff 64bit]
[ 0.206016] pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
[ 0.206130] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.206197] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.206216] pci 0000:02:00.0: reg 0x10: [io 0xe000-0xe0ff]
[ 0.206242] pci 0000:02:00.0: reg 0x18: [mem 0xf7d00000-0xf7d00fff 64bit]
[ 0.206259] pci 0000:02:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.206347] pci 0000:02:00.0: supports D1 D2
[ 0.206348] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.206390] pci 0000:02:00.0: System wakeup disabled by ACPI
[ 0.219249] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.219252] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.219255] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.219259] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.219336] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
[ 0.219455] pci 0000:03:00.0: supports D1 D2
[ 0.219457] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.219478] pci 0000:03:00.0: System wakeup disabled by ACPI
[ 0.219506] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[ 0.219510] pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.219567] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.219590] pci 0000:04:00.0: reg 0x10: [mem 0xf7c00000-0xf7c0ffff]
[ 0.219793] pci 0000:03:00.0: PCI bridge to [bus 04] (subtractive decode)
[ 0.219806] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.219815] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff] (subtractive decode)
[ 0.220527] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.220564] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.220600] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.220636] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.220671] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.220710] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.220748] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.220783] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.221032] ACPI: Enabled 4 GPEs in block 00 to 3F
[ 0.221130] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.221132] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.221136] vgaarb: loaded
[ 0.221136] vgaarb: bridge control possible 0000:00:02.0
[ 0.221198] PCI: Using ACPI for IRQ routing
[ 0.222452] PCI: pci_cache_line_size set to 64 bytes
[ 0.222494] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[ 0.222496] e820: reserve RAM buffer [mem 0xc9d5e000-0xcbffffff]
[ 0.222497] e820: reserve RAM buffer [mem 0xca5a8000-0xcbffffff]
[ 0.222497] e820: reserve RAM buffer [mem 0xda38f000-0xdbffffff]
[ 0.222498] e820: reserve RAM buffer [mem 0xda463000-0xdbffffff]
[ 0.222499] e820: reserve RAM buffer [mem 0xdb000000-0xdbffffff]
[ 0.222500] e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff]
[ 0.222618] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.222623] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.224638] clocksource: Switched to clocksource hpet
[ 0.232435] VFS: Disk quotas dquot_6.6.0
[ 0.232454] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.232534] pnp: PnP ACPI init
[ 0.232667] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.232671] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.232812] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.232813] system 00:01: [io 0xffff] has been reserved
[ 0.232815] system 00:01: [io 0xffff] has been reserved
[ 0.232816] system 00:01: [io 0xffff] has been reserved
[ 0.232817] system 00:01: [io 0x1c00-0x1cfe] has been reserved
[ 0.232818] system 00:01: [io 0x1d00-0x1dfe] has been reserved
[ 0.232820] system 00:01: [io 0x1e00-0x1efe] has been reserved
[ 0.232821] system 00:01: [io 0x1f00-0x1ffe] has been reserved
[ 0.232822] system 00:01: [io 0x1800-0x18fe] has been reserved
[ 0.232823] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.232825] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.232847] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.232888] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.232890] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.232991] system 00:04: [io 0x0a00-0x0a0f] has been reserved
[ 0.232992] system 00:04: [io 0x0a30-0x0a3f] has been reserved
[ 0.232993] system 00:04: [io 0x0a20-0x0a2f] has been reserved
[ 0.232995] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.233029] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.233212] pnp 00:06: [dma 0 disabled]
[ 0.233249] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.233469] pnp 00:07: [dma 0 disabled]
[ 0.233560] pnp 00:07: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.233602] system 00:08: [io 0x04d0-0x04d1] has been reserved
[ 0.233604] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.233931] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.233933] system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.233934] system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.233935] system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.233937] system 00:09: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.233938] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.233939] system 00:09: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.233940] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.233942] system 00:09: [mem 0xff000000-0xffffffff] has been reserved
[ 0.233943] system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.233945] system 00:09: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[ 0.233946] system 00:09: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.233948] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.234111] pnp: PnP ACPI: found 10 devices
[ 0.240128] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.240162] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.240171] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.240173] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.240177] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.240179] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.240184] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.240191] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.240204] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[ 0.240208] pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.240214] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.240216] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.240217] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.240218] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.240219] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.240220] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.240221] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.240223] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.240224] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
[ 0.240225] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff window]
[ 0.240226] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.240227] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.240228] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.240229] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.240230] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.240231] pci_bus 0000:04: resource 4 [mem 0xf7c00000-0xf7cfffff]
[ 0.240308] NET: Registered protocol family 2
[ 0.240436] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.240599] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes)
[ 0.240981] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.241016] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.241084] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.241180] NET: Registered protocol family 1
[ 0.241191] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.288748] PCI: CLS 64 bytes, default 64
[ 0.288795] Unpacking initramfs...
[ 0.584563] Freeing initrd memory: 23464K
[ 0.584566] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.584568] software IO TLB [mem 0xd638f000-0xda38f000] (64MB) mapped at [ffffa0b05638f000-ffffa0b05a38efff]
[ 0.584863] audit: initializing netlink subsys (disabled)
[ 0.584879] audit: type=2000 audit(1546955512.584:1): initialized
[ 0.585227] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[ 0.586550] zbud: loaded
[ 0.587266] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.587292] io scheduler noop registered
[ 0.587293] io scheduler deadline registered
[ 0.587319] io scheduler cfq registered (default)
[ 0.587728] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.587732] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.587747] intel_idle: MWAIT substates: 0x2120
[ 0.587748] intel_idle: v0.4.1 model 0x3C
[ 0.587802] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.587899] GHES: HEST is not enabled!
[ 0.587949] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.608369] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.608860] Linux agpgart interface v0.103
[ 0.608946] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.608946] AMD IOMMUv2 functionality not available on this system
[ 0.609098] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.609098] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.609267] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.609365] mousedev: PS/2 mouse device common for all mice
[ 0.609400] rtc_cmos 00:02: RTC can wake from S4
[ 0.609512] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.609574] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.609583] intel_pstate: Intel P-state driver initializing
[ 0.611227] NET: Registered protocol family 10
[ 0.611855] mip6: Mobile IPv6
[ 0.611861] NET: Registered protocol family 17
[ 0.611868] mpls_gso: MPLS GSO support
[ 0.612258] microcode: sig=0x306c3, pf=0x2, revision=0x19
[ 0.612367] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.612791] registered taskstats version 1
[ 0.612841] zswap: loaded using pool lzo/zbud
[ 0.612957] ima: No TPM chip found, activating TPM-bypass!
[ 0.612961] ima: Allocated hash algorithm: sha256
[ 0.613904] rtc_cmos 00:02: setting system clock to 2019-01-08 13:51:52 UTC (1546955512)
[ 0.614082] PM: Hibernation image not present or could not be loaded.
[ 0.617033] Freeing unused kernel memory: 1680K
[ 0.617035] Write protecting the kernel read-only data: 12288k
[ 0.618754] Freeing unused kernel memory: 1784K
[ 0.625605] Freeing unused kernel memory: 1184K
[ 0.629468] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.638034] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.666547] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.666681] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.666700] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.727731] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.727734] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.728228] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.728230] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.734816] ACPI: bus type USB registered
[ 0.734843] usbcore: registered new interface driver usbfs
[ 0.734856] usbcore: registered new interface driver hub
[ 0.735227] usbcore: registered new device driver usb
[ 0.735769] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.735981] ehci-pci: EHCI PCI platform driver
[ 0.736178] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.736188] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.736201] ehci-pci 0000:00:1a.0: debug port 2
[ 0.737821] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.737829] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.740102] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.740165] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7e1c000
[ 0.741099] SCSI subsystem initialized
[ 0.749606] r8169 0000:02:00.0 eth0: RTL8168g/8111g at 0xffffb51dc0a7d000, 40:8d:5c:81:32:43, XID 0c000800 IRQ 24
[ 0.749609] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.752087] libata version 3.00 loaded.
[ 0.752693] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.752919] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.752921] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.752923] usb usb1: Product: EHCI Host Controller
[ 0.752924] usb usb1: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[ 0.752926] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.763213] hub 1-0:1.0: USB hub found
[ 0.763225] hub 1-0:1.0: 2 ports detected
[ 0.763533] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.763538] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.764617] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[ 0.764622] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.766170] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.766172] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.766174] usb usb2: Product: xHCI Host Controller
[ 0.766175] usb usb2: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[ 0.766177] usb usb2: SerialNumber: 0000:00:14.0
[ 0.768280] hub 2-0:1.0: USB hub found
[ 0.768297] hub 2-0:1.0: 10 ports detected
[ 0.772910] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.772914] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.772955] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.772957] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.772958] usb usb3: Product: xHCI Host Controller
[ 0.772960] usb usb3: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[ 0.772961] usb usb3: SerialNumber: 0000:00:14.0
[ 0.773168] hub 3-0:1.0: USB hub found
[ 0.773176] hub 3-0:1.0: 2 ports detected
[ 0.773405] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[ 0.773535] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[ 0.773589] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 0.774479] ahci 0000:00:1f.2: version 3.0
[ 0.774655] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x1 impl SATA mode
[ 0.774658] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems
[ 0.779170] scsi host0: ahci
[ 0.779286] scsi host1: ahci
[ 0.779383] scsi host2: ahci
[ 0.779481] scsi host3: ahci
[ 0.779531] ata1: SATA max UDMA/133 abar m2048@0xf7e1a000 port 0xf7e1a100 irq 26
[ 0.779533] ata2: DUMMY
[ 0.779533] ata3: DUMMY
[ 0.779534] ata4: DUMMY
[ 0.779761] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.779766] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 0.779776] ehci-pci 0000:00:1d.0: debug port 2
[ 0.783680] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.783718] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7e1b000
[ 0.796701] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.797160] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.797162] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.797163] usb usb4: Product: EHCI Host Controller
[ 0.797164] usb usb4: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[ 0.797165] usb usb4: SerialNumber: 0000:00:1d.0
[ 0.797396] hub 4-0:1.0: USB hub found
[ 0.797403] hub 4-0:1.0: 2 ports detected
[ 1.088744] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.100274] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.100696] usb 2-4: new full-speed USB device number 2 using xhci_hcd
[ 1.100858] ata1.00: ATA-9: C300-MTFDBAK128MAG, 0308, max UDMA/100
[ 1.100862] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.101634] ata1.00: configured for UDMA/100
[ 1.102054] scsi 0:0:0:0: Direct-Access ATA C300-MTFDBAK128M 0308 PQ: 0 ANSI: 5
[ 1.124724] usb 4-1: new high-speed USB device number 2 using ehci-pci
[ 1.136347] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 1.136432] sd 0:0:0:0: [sda] Write Protect is off
[ 1.136435] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.136455] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.137062] sda: sda1 sda2 < sda5 sda6 >
[ 1.137535] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.192379] PM: Starting manual resume from disk
[ 1.192382] PM: Hibernation image partition 8:5 present
[ 1.192383] PM: Looking for hibernation image.
[ 1.192544] PM: Image not found (code -22)
[ 1.192545] PM: Hibernation image not present or could not be loaded.
[ 1.237111] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[ 1.237113] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.237401] hub 1-1:1.0: USB hub found
[ 1.237485] hub 1-1:1.0: 4 ports detected
[ 1.241506] usb 2-4: New USB device found, idVendor=1a86, idProduct=7523
[ 1.241508] usb 2-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.241509] usb 2-4: Product: USB2.0-Serial
[ 1.273091] usb 4-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.273094] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.273242] hub 4-1:1.0: USB hub found
[ 1.273339] hub 4-1:1.0: 6 ports detected
[ 1.297450] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.298305] random: fast init done
[ 1.360694] usb 2-5: new low-speed USB device number 3 using xhci_hcd
[ 1.384133] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.388704] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.388806] systemd[1]: Detected architecture x86-64.
[ 1.388964] systemd[1]: Set hostname to <cnc-debian>.
[ 1.440097] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 1.440110] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[ 1.440582] systemd[1]: Listening on udev Control Socket.
[ 1.440724] systemd[1]: Listening on Journal Audit Socket.
[ 1.440761] systemd[1]: Listening on Syslog Socket.
[ 1.440910] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.440940] systemd[1]: Listening on udev Kernel Socket.
[ 1.465272] lp: driver loaded but no devices found
[ 1.466729] ppdev: user-space parallel port driver
[ 1.467417] parport_pc 00:07: reported by Plug and Play ACPI
[ 1.467485] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 1.471549] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[ 1.505521] usb 2-5: New USB device found, idVendor=046d, idProduct=c408
[ 1.505523] usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.505524] usb 2-5: Product: USB Trackball
[ 1.505525] usb 2-5: Manufacturer: Logitech
[ 1.569004] lp0: using parport0 (interrupt-driven).
[ 1.600682] tsc: Refined TSC clocksource calibration: 3092.838 MHz
[ 1.600687] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c94d9afcf4, max_idle_ns: 440795231738 ns
[ 1.628685] usb 2-6: new full-speed USB device number 4 using xhci_hcd
[ 1.669450] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.669454] ACPI: Power Button [PWRB]
[ 1.670564] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.670566] ACPI: Power Button [PWRF]
[ 1.701435] systemd-journald[201]: Received request to flush runtime journal from PID 1
[ 1.769609] usb 2-6: New USB device found, idVendor=10ce, idProduct=eb70
[ 1.769612] usb 2-6: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 1.769613] usb 2-6: Manufacturer: KTURT.LTD
[ 1.860206] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.877436] usbcore: registered new interface driver usbhid
[ 1.877438] usbhid: USB HID core driver
[ 1.913036] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.926275] [drm] Initialized
[ 1.972222] [drm] PipeC fused off
[ 1.972232] [drm] Memory usable by graphics device = 2048M
[ 1.972234] [drm] Replacing VGA console driver
[ 1.976290] Console: switching to colour dummy device 80x25
[ 1.983827] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.983828] [drm] Driver supports precise vblank timestamp query.
[ 2.001984] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 2.038511] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 2.043798] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[ 2.048573] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 2.048579] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[ 2.049258] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.050225] snd_hda_codec_realtek hdaudioC1D2: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 2.050227] snd_hda_codec_realtek hdaudioC1D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.050228] snd_hda_codec_realtek hdaudioC1D2: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 2.050229] snd_hda_codec_realtek hdaudioC1D2: mono: mono_out=0x0
[ 2.050230] snd_hda_codec_realtek hdaudioC1D2: dig-out=0x11/0x0
[ 2.050231] snd_hda_codec_realtek hdaudioC1D2: inputs:
[ 2.050233] snd_hda_codec_realtek hdaudioC1D2: Rear Mic=0x18
[ 2.050234] snd_hda_codec_realtek hdaudioC1D2: Front Mic=0x19
[ 2.050235] snd_hda_codec_realtek hdaudioC1D2: Line=0x1a
[ 2.050236] snd_hda_codec_realtek hdaudioC1D2: CD=0x1c
[ 2.053802] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 2.062595] fbcon: inteldrmfb (fb0) is primary device
[ 2.070847] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card1/input5
[ 2.086566] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input6
[ 2.095617] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input7
[ 2.096777] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 2.096777] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 2.096778] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 2.096778] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 2.096778] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 2.100242] usbcore: registered new interface driver usbserial
[ 2.100565] usbcore: registered new interface driver usbserial_generic
[ 2.100969] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input8
[ 2.101083] usbserial: USB Serial support registered for generic
[ 2.103925] usbcore: registered new interface driver ch341
[ 2.104328] usbserial: USB Serial support registered for ch341-uart
[ 2.104430] ch341 2-4:1.0: ch341-uart converter detected
[ 2.104518] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input9
[ 2.107404] usb 2-4: ch341-uart converter now attached to ttyUSB0
[ 2.124064] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input10
[ 2.127786] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input11
[ 2.131838] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input12
[ 2.140744] Console: switching to colour frame buffer device 210x65
[ 2.159125] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 2.178852] input: Logitech USB Trackball as /devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/0003:046D:C408.0001/input/input13
[ 2.178941] hid-generic 0003:046D:C408.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Trackball] on usb-0000:00:14.0-5/input0
[ 2.179392] hid-generic 0003:10CE:EB70.0002: hiddev0,hidraw1: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:14.0-6/input0
[ 2.180056] Adding 4085756k swap on /dev/sda5. Priority:-1 extents:1 across:4085756k SSFS
[ 2.219728] intel_rapl: Found RAPL domain package
[ 2.219729] intel_rapl: Found RAPL domain core
[ 2.219730] intel_rapl: Found RAPL domain uncore
[ 2.219730] intel_rapl: Found RAPL domain dram
[ 2.236106] iTCO_vendor_support: vendor-support=0
[ 2.242191] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 2.242477] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 2.628721] clocksource: Switched to clocksource tsc
[ 2.646836] r8169 0000:02:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[ 2.719040] r8169 0000:02:00.0 eth0: link down
[ 2.719045] r8169 0000:02:00.0 eth0: link down
[ 2.719119] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.166113] r8169 0000:02:00.0 eth0: link up
[ 5.166130] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.138465] random: crng init done
[ 13.138467] random: 7 urandom warning(s) missed due to ratelimiting
