Het idee was om te ontwerpen en een 3D-printer die is eenvoudig te monteren, eenvoudig te verplaatsen en te reizen met behulp van eenvoudig materialen te bouwen. Thats about all my dutch
Built from 20m x 20mm x 1.5mm square aluminium pipe from the Gamma/Praxxis
Electronics: Ramps 1.4 with LCD controller
Hotend: J type Hotend 1.75mm
Extruder: Own design (reprap wiki :teestruder)
Estimated Build cost 400 Euros
Tips & Ideas on how to make it much better are welcome.
The design fully assembled...
The design folded...
Video printing...
Photos of completed machine..
Many on this website are expert builders of CNC machines. I will not bother you with the boring steps of how I built the 3D printer. the photos say much. Detail instruction manual and STL files on Git hub. Feel free to build one or modify it for your use, If you do I will be glad to here from you!!
STL files : https://github.com/EmmanuelAdetutu/TeeBotMax
more photos on my blog http://tutuemma.wordpress.com/3d-stuffs/teebotmax/
Dream...and create if it does not work... do it again..
TeeBotMax foldable, 3D printer DIY Manual & STL
