post processor Powermill?
Swets
Re: post processor Powermill?
Bericht door Swets »
Ja ze beginnen allemaal haast met de fanuc.pmopt
dus dacht ook daar maar mee te beginnen....
eerst dit stukje maar.... das best wel belangrijk denk ik....
die zal wel een beetje het zelfde moeten worden dan de MTD- File?
<?xml version="1.0" ?>
<!-- 5-axis Table-Table configuration -->
<!-- Table static apart from rotary motion, Head moves in X, Y & Z -->
<!-- Both rotary axes on table controlled by B & C -->
<!-- Note the restricted movement on B axis -->
<machine xmlns="x-schema:PowermillMachineTool" POST="pmpMultiaxis.*">
  <!-- Where things are attached to the machine -->
  <table_attach_point PART="table" X="0" Y="0" Z="0" />
  <head_attach_point PART="head" X="-271.950" Y="-424.50" Z="198.713" I="0" J="0" K="1" />
<!-- Frame -->
<machine_part>
        <model_list>
          <dmt_file>
            <path FILE="machine_parts_arjan/Frame.dmt" />
            <rgb R="150" G="150" B="150" />
          </dmt_file>
         </model_list>
          </machine_part>
  <!-- The head -->
  <machine_part>
    <axis>
      <control_info ADDRESS="X"  MIN="0" MAX="760" />
      <simple_linear I="1" J="0" K="0" />
    </axis>
		  <model_list>
          <dmt_file>
            <path FILE="machine_parts_Arjan/X_as.dmt" />
          </dmt_file>
        </model_list>
    <machine_part>
      <axis>
 <control_info ADDRESS="Y" MIN="0" MAX="610" />
        <simple_linear I="0" J="1" K="0" />
      </axis>
	  <model_list>
          <dmt_file>
            <path FILE="machine_parts_Arjan/Y_as.dmt" />
            <rgb R="150" G="150" B="140" />
          </dmt_file>
        </model_list>
      <machine_part>
        <axis>
          <control_info ADDRESS="Z" VALUE="280"  MIN="0" MAX="280" />
          <simple_linear I="0" J="0" K="1" />
        </axis>
        <model_list>
          <dmt_file>
            <path FILE="machine_parts_Arjan/Z_as.dmt" />
            <rgb R="150" G="140" B="150" />
          </dmt_file>
        </model_list>
        <machine_part NAME="head" />
      </machine_part>
    </machine_part>
  </machine_part>
  <!-- The table -->
  <machine_part>
    <axis>
      <control_info ADDRESS="B" MIN="-100" MAX="100" />
      <simple_rotary X="0" Y="0" Z="34.5" I="0" J="1" K="0" />
    </axis>
    <model_list>
      <dmt_file>
        <path FILE="machine_parts_Arjan/B_as.dmt" />
        <rgb R="140" G="150" B="150" />
      </dmt_file>
    </model_list>
    <machine_part>
      <axis>
        <control_info ADDRESS="C" />
        <simple_rotary X="0" Y="0" Z="0" I="0" J="0" K="-1" />
      </axis>
      <model_list>
        <dmt_file>
          <path FILE="machine_parts_Arjan/C_as.dmt" />
          <rgb R="255" G="255" B="200" />
        </dmt_file>
      </model_list>
      <machine_part NAME="table"/>
    </machine_part>
  </machine_part>
</machine>
Swets
volgens mij zij de richting van de assen zo goed?
en dan zie ik dit plaatje:
nu waarschijnlijk de maten zal ik ook nog wel ergens in moeten vullen?
Swets
tja... :-) ik weet ff niet wat ik moet zien?
hoe weet ik nu of het goed is?
Denk niet dat het zo moet....
want ik wil eigenlijk straks nullen op de hart van de draaitafel.... en daar alles op 0 zetten?
dus ik denk dat ik alleen die 34,5 erin moet zetten?
Help... :-)
Swets
H.C
Bericht door H.C »
in het begin deed ik dat ook (vanwege geen home switches) maar dat is redelijk gevaarlijk :)
sommige posts doen een g28 op het einde...ra ra :) heb dit op de harde manier geleerd.
dus daar MOET uw g54 liggen,
momenteel gebruik ik een fanuc 30i op een eding controler (vergelijkbaar met mach)
het is vooral een kwestie om de M codes uit de postprocessor the halen.
Swets
jaja....
dus wel beter dus?
dan moet ik op mijn machine de X en Y goed uitzoeken....
want die van de simulatie, heb ik van de cad tekeningen gemeten....
maar op de machine kan er wel verschil in zitten....
moet nog ff flink uitzoeken hoe het nu allemaal moet.... tis niet echt ff simpel...
H.C
Bericht door H.C »
niet moeilijker maken dat het is :) (alles draait rond dat middelpunt, rest kan je later aanpassen)
begin gewoon met een kubus midden op uw trunnion, Een facing toolpath op de 5 zijden > run post
kan je mooi de a/b beweging zien in de gcode
van daaruit begin je bij te werken.
Swets
Dus ik plaats bij die Machine Kinematics even geen verschuiving in bij x en y as...
alleen die 34,5 die de C as onder het draaipunt van de B-as ligt....
nee ik wil het zeker niet moeilijker maken...:-)... tis allemaal al moeilijk zat voor me...
(tis ook allemaal nieuw natuurlijk voor mij... )
oja... als ik van 5 kanten wil frezen.... moet ik een workplane op dat vlak maken, en die dan kiezen bij het frezen?
als dan alles goed is draai de machine zelf naar dat vlak toe?
(misschien beetje domme vraag... maar ja net wat ik al zei, tis allemaal nieuw voor mij... Powermill en 5 assen...)
zit me ook net te bedenken? had ik dan die simulatie ook niet zonder die verschuiving moeten maken?
kan je in die simulatie ook ergens zeggen waar je machine staat?
In mach 3 heb je 2 coordinaten... je machine coordinaten, die altijd beginnen op de plek war je je machine gehomed heb...
maar dan jog ik me machine normaal naar een bepaalde plek... en daar druk ik me tellers op 0... kan dat in de simulatie ook?
voel me opeens zo dom... :-)
shovel
Bericht door shovel »
Swets schreef: 29 jun 2022 15:20
Dit klopt inderdaad.
Volgens mij moet je straks ook altijd je nulpunt in het hart van je rotatie assen leggen.
Dit omdat de machine zelf niks uitrekent en dit het enige punt is waar de afstanden dan hetzelfde blijven naar je rotatie
Het niet hebben van RTCP maakt het wel een stuk lastiger
Daar heb ik geen ervaring mee
Als ik mijn machine toevoeg komt hij ook echt daar te staan.
Ik zie bij jou een ander plaatje als jou machine
Swets
pfff tis wel pittig... maar alle begin is moeilijk....
het is in het begin alleen altijd heel veel wat fout kan zijn.... maar het gaat goed komen,...
zolang ik maar hulp krijg... :-)
ik dacht , ik zal eens een test dingetje maken...
zodat ik ook een toolpad kan genereren, zodat ik die kan controloeren....
maar als je naar me filmpje kijk, ziet het toelpad er goed uit, tot ik ga simuleren?
ik snap niet helemaal wat ik fout doe....:-) want ik zal het wel fout doen...
Ja die termen RTCP zegt me ook allemaal nog niets?
dus in mijn geval, moet ik het model, in de z richting 34,5 omhoog schuiven....
wat ik bij dat toolpad in me film ook niet begreep, terwijl ik het model 20mm omhoog had geschoven, het toolpad toch tot te tafel ging, ik had verwacht dat hij dan 20 mm boven de tafel zou blijven?
H.C
Bericht door H.C »
is de top van uw C ook het middelpunt rotaties ?
maak eens een plane op uw centerpunt a/c > bij machinetool selecteer je deze plane & niet top.
Swets
nee, ik heb de de top van 6 echt op de C vlak liggen... had ik die beter 34,5 hoger kunnen leggen?
dan legt hij op het draaipunt van de B-as....
H.C
Bericht door H.C »
edit :)
(vermoed dat je een Z offset hebt in de B 34.5)
dus,
je maakt een plane op de B (selecteer die blauwe pijlen) >>> deze gebuik je in de toolpath voor machinetool> model location.
bij workplane, probeer met none of top of de plane op de B
zeker een zal werken :)))
H.C
Bericht door H.C »
Ik ben wel benieuwd of die offset geen problemen gaat geven in de post.
(daarom ben ik meer voorstander voor de setup in uw MTD8 video)
