Alu-profile-based enclosed 250x150x100 desktop CNC
Jacek
Re: Alu-profile-based enclosed 250x150x100 desktop CNC
Bericht door Jacek »
Thanks for your comments. The purpose of this test was not to achieve quality surfaces, but to check how capable tha machine is with removing material. I used a broken endmill (a victim of me previous experiments). In several runs (most of runs in this experiment) I had moments when the endmill was going into low frequency high energy vibration (almost trying to move the whole machine) and it was immediately visible in accuracy of side edges. I need to repeat the runs with brand new endmill.
By the way. I am looking for some interesting test piece ideas in alu, plexi, wood. Standard "square-diamond-circle" tester is boooring.
Jacek Tylenda - Ik hou van CNC-machines!
Jacek
This weekend i played a bit with engraving, v-carving, adaptive pocket clearing in anodised aluminium and wood.
In the meantime I broke two 6mm endmills - the chase for maximum MRR is still ongoing. So far this is the best I have achieved:
6mm VHM 3-flute straight endmill
12k RPM
F1800 mm/min
Ap 5,5
Ae 1,0
MRR 9,9 cm^3/min !!!
Anything faster than that (higher MRR) results in too much heat buildup and broken bits. I was successfully running at F2500mm/min with a 4-flute endmill, but the Ap was jsut 3 mm. Still - I was surprised that it could go that fast.
Mooie resultaten.
Look who made serious progress!!! Nice results for sure.
Jacek schreef: 13 feb 2023 00:36 MRR 9,9 cm^3/min !!!
That is a serious material removal rate.
Very nice looking resuls.
Kars-cnc
Bericht door Kars-cnc »
Very nice results! I'm pleased to see you also discovered the Beech wood door step from construction market as a convenient material for milling :P
What mill type did you use to achieve the very smooth pit around the letters DoM?
Kars-cnc schreef: 14 feb 2023 18:17 I'm pleased to see you also discovered the Beech wood door step from construction market as a convenient material for milling :P
Will the source for the inspiration please rise. :mrgreen:
Jacek
This was my source of inspiration:
And indeed - bought a doorstep at Hornbach :-)
For the 3d smooth surface in wood I used 2mm 2flute VHM ballnose endmill and passes with 0,2mm stepover (that after first running adaptive clearing with 4mm 2-flute HSS, leaving just about ~0,5 mm steps for finishing). Took some time thou...
Jacek
Ik vond het de laatste tijd best leuk om video's te maken/bewerken. Ik heb veel foto's en beeldmateriaal van mijn doe-het-zelf-CNC-machine. Als je geïnteresseerd bent in de technische details van dit kleine beest: deel 1 van mijn videoserie is nu live op YouTube! Geniet ervan en blijf op de hoogte van de volgende afleveringen: montage, tuning en upgrades en uiteraard - prestaties.
Ik ben benieuwd naar de upgrades en het effect op het resultaat.
Jacek
De tweede video staat nu live op YouTube. Deze behandelt het montageproces met veel details. Verbeteringen komen aan bod in deel 3, prestaties in deel 4.
Jacek
De derde video staat nu live op YouTube. Deze behandelt kalibratie en wat kleine verbeteringen:
JoepS
Bericht door JoepS »
Leuke video's! Ik vind de compacte hall effect sensoren ook een leuk idee. Hebben die een voordeel t.o.v. inductieve sensoren? En heb je de as van stappenmotoren zelf vervangen met trapeziumdraad?
Jacek
Deze hall-effectsensoren zijn vrij goedkoop, ongeveer 7 euro per stuk, en erg klein. Ik bereikte een zeer goede herhaalbaarheid, op micrometerniveau.
Ik kocht de motoren onmiddellijk met een trapeziumschroef. Ik heb er één uit elkaar gehaald om te kijken hoe het er van binnen uitzag. De schroef lijkt gevuld te zijn met wat hars in de rotor. Ik heb alleen de schroeven op maat ingekort.
